# Login Redirect and/or Group Page Banner Component
**URL:** https://meta.discourse.org/t/login-redirect-and-or-group-page-banner-component/389120
**Category:** Theme component
**Created:** [November 19, 2025, 11:32pm UTC](https://meta.discourse.org/t/login-redirect-and-or-group-page-banner-component/389120 "2025-11-19T23:32:12Z")
**Posts on this page:** 1
**Page:** 1
<div class="post-metadata">
### Author: ![Drew-ART](https://avatars.discourse-cdn.com/v4/letter/d/8edcca/32.png) [@Drew-ART](https://meta.discourse.org/u/Drew-ART)
#### Post date: [November 19, 2025, 11:32pm UTC](https://meta.discourse.org/t/login-redirect-and-or-group-page-banner-component/389120/1 "2025-11-19T23:32:12Z")
</div>
This component allows you to redirect users anywhere you like after login, and also allows you to put a welcome banner in the groups ( /g ) page.
Install this theme component
Its built with both parts independent, so you can redirect anywhere you want, or use it just to put a banner in the groups page. The default behaviour is to redirect new users to the group page where a welcome banner encourages them to join groups to help them engage with your community.
 ![image](https://global.discourse-cdn.com/meta/original/4X/a/0/f/a0f2b4db634b8a775c4357b8d5352ff8514b9a90.jpeg)
You can also use this component to redirect user under a certain trust level to a page on login, or users who have joined below an amount of groups you select.
[https://github.com/focallocal/first-login-redirect](https://github.com/focallocal/first-login-redirect)
# First Login Redirect
A Discourse theme component that redirects users without group memberships to a custom page and displays a customizable welcome banner.
## Features
- **Smart Redirect** - Redirects users without group memberships to a custom page on login
- **Customizable Banner** - Colorful welcome banner on groups page
- **Fully Configurable** - Enable/disable redirect and banner independently
- **Group-based logic** - Stops redirecting once user joins any group
- **Trust Level aware** - Banner visibility can be restricted by trust level
- **Rainbow Gradient** - Eye-catching 6-color gradient background (with toggle for solid color)
- **Mobile responsive** - Banner adapts to mobile screens
## Installation
1. In the Discourse Admin console, go to **Customize → Themes → Components** and click **Install**
2. Choose **From a Git repository** and paste:
3. Once installed, add the component to your active theme
## How It Works
### Redirect Logic
- Checks if user is a member of any groups
- Detects when they navigate to the homepage
- Redirects them to configured URL (default: `/g`)
- Stops redirecting once they join any group
- Can be disabled independently of banner
### Welcome Banner
- Shows on groups index page (`/g`) by default
- Visibility controlled by trust level settings
- Can be disabled independently of redirect
- Automatically hidden once user reaches Trust Level 1
- Positioned at top of groups list using `before-groups-index` outlet
## Customization
### Theme Settings (Admin Panel)
 ![image](https://global.discourse-cdn.com/meta/original/4X/6/7/5/6753c32f91e8c4b1325df3f04df6d44a429a80c1.png)
All customization can be done from the Discourse admin panel without editing code!
1. Go to **Admin → Customize → Themes**
2. Click on your theme that includes this component
3. Go to **Settings** and find the “First Login Redirect” section
**Available Settings:**
**Redirect Settings:**
- **Enable Redirect** : Turn redirect feature on/off (default: true)
- **Min Groups Required** : How many user-created groups they must join before redirect stops (default: 1)
  - Automatic groups (like trust\_level\_0, everyone) don’t count
- **Redirect URL** : Where to send users without groups (default: `/g`)
  - Examples: `/g` (groups), `/categories`, `/about`, `/latest`
**Banner Settings:**
- **Show Banner** : Toggle the banner on/off (default: true)
- **Min Trust Level** : Minimum trust level to see banner (0-4, default: 0)
- **Max Trust Level** : Maximum trust level to see banner (0-4, default: 4)
- **Banner Heading** : Main large text
- **Banner Subheading** : Smaller explanatory text
**Typography:**
- **Heading Font Size** : Size of main heading (default: 2.5em)
- **Subheading Font Size** : Size of subheading (default: 1.25em)
- **Text Shadow Enabled** : Toggle text shadow for readability
- **Text Glow Enabled** : Toggle outer glow effect
**Colors:**
- **Use Gradient** : Enable/disable gradient (if disabled, uses solid color)
- **Gradient Color 1-6** : Customize each color in the gradient
  - Default: Pink → Orange → Yellow → Green → Cyan
  - Set “Use Gradient” to OFF for solid color using Color 1
**Layout:**
- **Banner Padding** : Space inside banner (default: 3rem 2rem)
- **Border Radius** : Corner roundness (default: 12px, use 0 for square)
 ![image](https://global.discourse-cdn.com/meta/original/4X/3/d/0/3d05b47399c293ba9dc3bfda062631094114d488.png)
 ![image](https://global.discourse-cdn.com/meta/original/4X/8/5/5/85550a17169a6177afcff07c63988c82f6e73d80.png)
### Examples
**Show for TL0 only (new users):**
Set Min Trust Level = 0, Max Trust Level = 0
**Show for everyone except admins:**
Set Min Trust Level = 0, Max Trust Level = 3
**Solid Color Banner:**
Turn OFF “Use Gradient” and set Color 1 to your desired color (e.g., `#FF5722` for orange).
**Two-Tone Gradient:**
Turn ON “Use Gradient” and set colors 1-3 to one color, colors 4-6 to another.
**Larger Text:**
Set heading to `3em` and subheading to `1.5em`.
**No Effects:**
Disable both “Text Shadow” and “Text Glow” for flat text.
### Disable Redirect (Banner Only)
Delete or comment out the file:
`javascripts/discourse/api-initializers/first-login-redirect.js`
### Change Trust Level Requirement
In both initializer files, change:
```javascript
currentUser.trust_level === 0
to:
```javascript
currentUser.trust_level <= 1 // TL0 and TL1
## Technical Details
- **API Version** : 1.8.0 (modern Discourse API)
- **Component Type** : Glimmer component with template tag
- **Plugin Outlet** : `before-groups-index`
- **Compatibility** : Discourse 2.8.0+
## Troubleshooting
**Q: Redirect not working**
A: Clear your browser’s sessionStorage and test with a fresh Trust Level 0 account
**Q: Banner not showing on testing**
A: Verify you’re on `/g` route and logged in as TL0 user, or the values you set in admin. Check browser console for errors.
**Q: Redirect loop**
A: The sessionStorage check should prevent this. If it occurs, clear browser cache and sessionStorage.
## License
MIT — Public Happiness Movement
