Long loading times for user summary page with slow database
Hi,
we’re facing huge loading times accessing a users summary page. It seems that it takes longer to load the summary the more active a user interacts with our site. Which, yes, seems quite obvious, but the difference in loading times on our site is immense.
So loading a “new” users (some weeks of activity) summary page takes ~1sec but loading a users page, who has a daily activity for years, takes up to 30-40secs.
So we’ve checked the database and were quite impressed of the table size (including indexes) of topic_views which is 62 GB.
Here are our 7 biggest tables:
relation total_size table_size index_size reltuples
topic_views 62 GB 17 GB 45 GB 399215000
posts 27 GB 22 GB 5022 MB 9123860
top_topics 15 GB 708 MB 15 GB 1602180
post_search_data 15 GB 12 GB 2849 MB 8181010
incoming_links 12 GB 5330 MB 6647 MB 90008900
user_actions 3184 MB 877 MB 2307 MB 11872800
topics 2117 MB 1035 MB 1082 MB 1613070
To test this we’ve picked a user’s id of which we know has a huge loading time of the summaries and performed a count with that ID on the topic_views table. This query took nearly the same time as the summary of the user took to load. So the topics viewed part is responsible for this delay.
As explained in earlier topics we’ve upgraded an old (v1.2.4 + modifications) Discourse based site to v2.4.0-beta.2 and are now running Discourse v2.4.0-beta6. So may there could be some data left over. But we don’t know what can be deleted.
At this point we’re quite unsure what to do or tweak next. Our installation is running completely on azure using an external instance of Azure Database for PostgreSQL and we’ve applied the configuration described in your postgres.10.template.yml. We don’t even know if the size of the topic_views table (espacially the index) is “to big” in relation to the other tables or if it is quite normal.
Any hint, thought or idea is appreciated.
Kind Regards
Sascha Hofmann
P.S.
I forgot to mention that because of this we have several 502 Errors (displayed on the site itself, so no nginx errorpage or application gateway) loading /u/<username>/summary.json.
Are you viewing it as admin / staff or as anon? The staff view is far more expensive.
It makes no difference if I’m viewing /u/<username>/summary as admin/staff or with my normal user account. We also have hide user profiles from public enabled so user profiles are not visible for anon (disabled it for testing but makes no difference as topics viewed is also present in summary).
Have you migrated, modified or rebuilt the same database over and over? It’s possible your database needs a vacuum to update the statistics. 30s queries are way out of the normal range we see in Discourse installs (although admittedly your DB is large.)
VACUUM FULL is worth trying if you can accept some downtime.
Also is your database on fast ssd storage with a LOT of ram? That is critical.
In order to know exactly what is the problem:
  1. Edit the app.yml file and add your admin user email to DISCOURSE_DEVELOPER_EMAILS.
  2. Rebuild
  3. Load the slow page while logged in as the user set in step 1.
  4. Share the result of the mini-profiler
Share the contents from this and the expanded window:
We’ve tested it several times but always with a fresh copy of the old dataset. After a couple of weeks and as soon we we’re sure that we’ve reverted the changes of the previous owner successfully, we’ve run the upgrade and migration once.
That’s definitely worth a try but I’m not quite sure how long this will take. But yes, we should consider a full vacuum. Especially as we had some problems with the older database already.
Yep. All of the data is stored onto a server ssd and backed by 40GB RAM (of which ~60% are used overall without plateaus at 100% on higher loads).
Thanks for this advice, I’ll give it a try.
As we use our own docker-image, where app.yml is missing, we should achieve the same behaviour with adding the mail-address(es) to developer_emails in the discourse.conf.
You can go into the rails console and use Developers.create!(user_id: 123) where 123 is your user id.
Unfortunately it’s not working (yes I’ve replaced 123 before :slight_smile:) :
discourse@2d5c3bf04550:~$ rails console --environment=production
Loading production environment (Rails 6.0.0)
irb(main):001:0> Developers.create!(user_id: 123)
Traceback (most recent call last):
        1: from (irb):1
NameError (uninitialized constant Developers)
Another approach:
discourse@2d5c3bf04550:~$ rails runner --environment=production make_me_dev.rb
/var/www/discourse/bin/rails: Bootsnap::LoadPathCache::FallbackScan
	19: from /var/www/discourse/bin/rails:17:in `<main>'
	18: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.0/lib/active_support/dependencies.rb:325:in `require'
	17: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.0/lib/active_support/dependencies.rb:291:in `load_dependency'
	16: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.0/lib/active_support/dependencies.rb:325:in `block in require'
	15: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.4.4/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:30:in `require'
	14: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.4.4/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:21:in `require_with_bootsnap_lfi'
	13: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.4.4/lib/bootsnap/load_path_cache/loaded_features_index.rb:92:in `register'
	12: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.4.4/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:22:in `block in require_with_bootsnap_lfi'
	11: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.4.4/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:22:in `require'
	10: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.0/lib/rails/commands.rb:18:in `<main>'
	 9: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.0/lib/rails/command.rb:46:in `invoke'
	 8: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.0/lib/rails/command/base.rb:65:in `perform'
	 7: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/thor-0.20.3/lib/thor.rb:387:in `dispatch'
	 6: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/thor-0.20.3/lib/thor/invocation.rb:126:in `invoke_command'
	 5: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/thor-0.20.3/lib/thor/command.rb:27:in `run'
	 4: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.0/lib/rails/commands/runner/runner_command.rb:42:in `perform'
	 3: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.4.4/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:52:in `load'
	 2: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.4.4/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:69:in `rescue in load'
	 1: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.4.4/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:69:in `load'
make_me_dev.rb:1:in `<main>': uninitialized constant Developers (NameError)
discourse@2d5c3bf04550:~$ cat make_me_dev.rb
I’ll try the discourse.conf - way and provide the requested data as soon as possible.
Thanks for your advice so far!
Well, that is way we always tell people to use the official supported method of installing Discourse, so when help is needed we can help out using standard tools.
Yeah, may it’s because we’re using supervisord to spawn all processes.
Anyway, here is the output you’ve requested (zipped html-content):
_u_x_strom_summary.json-13498.2ms-ProfilingResults.zip (94.5 KB)
This request took 13secs but I had to load the site twice. Again the first attempt took to long so it resulted in a 502 Error. So maybe some thing were cached already.
It took more than 13 seconds to run 51 SQL queries. Your database is seriously either misconfigured or underpowered.
Big offenders
SELECT "posts"."id" AS t0_r0, "posts"."user_id" AS t0_r1, "posts"."topic_id" AS t0_r2, "posts"."post_number" AS t0_r3, "posts"."raw" AS t0_r4, "posts"."cooked" AS t0_r5, "posts"."created_at" AS t0_r6, "posts"."updated_at" AS t0_r7, "posts"."reply_to_post_number" AS t0_r8, "posts"."reply_count" AS t0_r9, "posts"."quote_count" AS t0_r10, "posts"."deleted_at" AS t0_r11, "posts"."off_topic_count" AS t0_r12, "posts"."like_count" AS t0_r13, "posts"."incoming_link_count" AS t0_r14, "posts"."bookmark_count" AS t0_r15, "posts"."avg_time" AS t0_r16, "posts"."score" AS t0_r17, "posts"."reads" AS t0_r18, "posts"."post_type" AS t0_r19, "posts"."sort_order" AS t0_r20, "posts"."last_editor_id" AS t0_r21, "posts"."hidden" AS t0_r22, "posts"."hidden_reason_id" AS t0_r23, "posts"."notify_moderators_count" AS t0_r24, "posts"."spam_count" AS t0_r25, "posts"."illegal_count" AS t0_r26, "posts"."inappropriate_count" AS t0_r27, "posts"."last_version_at" AS t0_r28, "posts"."user_deleted" AS t0_r29, "posts"."reply_to_user_id" AS t0_r30, "posts"."percent_rank" AS t0_r31, "posts"."notify_user_count" AS t0_r32, "posts"."like_score" AS t0_r33, "posts"."deleted_by_id" AS t0_r34, "posts"."edit_reason" AS t0_r35, "posts"."word_count" AS t0_r36, "posts"."version" AS t0_r37, "posts"."cook_method" AS t0_r38, "posts"."wiki" AS t0_r39, "posts"."baked_at" AS t0_r40, "posts"."baked_version" AS t0_r41, "posts"."hidden_at" AS t0_r42, "posts"."self_edits" AS t0_r43, "posts"."reply_quoted" AS t0_r44, "posts"."via_email" AS t0_r45, "posts"."raw_email" AS t0_r46, "posts"."public_version" AS t0_r47, "posts"."action_code" AS t0_r48, "posts"."image_url" AS t0_r49, "posts"."locked_by_id" AS t0_r50, "topics"."id" AS t1_r0, "topics"."title" AS t1_r1, "topics"."last_posted_at" AS t1_r2, "topics"."created_at" AS t1_r3, "topics"."updated_at" AS t1_r4, "topics"."views" AS t1_r5, "topics"."posts_count" AS t1_r6, "topics"."user_id" AS t1_r7, "topics"."last_post_user_id" AS t1_r8, "topics"."reply_count" AS t1_r9, "topics"."featured_user1_id" AS t1_r10, "topics"."featured_user2_id" AS t1_r11, "topics"."featured_user3_id" AS t1_r12, "topics"."avg_time" AS t1_r13, "topics"."deleted_at" AS t1_r14, "topics"."highest_post_number" AS t1_r15, "topics"."image_url" AS t1_r16, "topics"."like_count" AS t1_r17, "topics"."incoming_link_count" AS t1_r18, "topics"."category_id" AS t1_r19, "topics"."visible" AS t1_r20, "topics"."moderator_posts_count" AS t1_r21, "topics"."closed" AS t1_r22, "topics"."archived" AS t1_r23, "topics"."bumped_at" AS t1_r24, "topics"."has_summary" AS t1_r25, "topics"."archetype" AS t1_r26, "topics"."featured_user4_id" AS t1_r27, "topics"."notify_moderators_count" AS t1_r28, "topics"."spam_count" AS t1_r29, "topics"."pinned_at" AS t1_r30, "topics"."score" AS t1_r31, "topics"."percent_rank" AS t1_r32, "topics"."subtype" AS t1_r33, "topics"."slug" AS t1_r34, "topics"."deleted_by_id" AS t1_r35, "topics"."participant_count" AS t1_r36, "topics"."word_count" AS t1_r37, "topics"."excerpt" AS t1_r38, "topics"."pinned_globally" AS t1_r39, "topics"."pinned_until" AS t1_r40, "topics"."fancy_title" AS t1_r41, "topics"."highest_staff_post_number" AS t1_r42, "topics"."featured_link" AS t1_r43, "topics"."reviewable_score" AS t1_r44 FROM "posts" INNER JOIN "topics" ON ("topics"."deleted_at" IS NULL) AND "topics"."id" = "posts"."topic_id" WHERE ("posts"."deleted_at" IS NULL) AND (posts.post_type IN (1,2,3,4)) AND ("topics"."deleted_at" IS NULL) AND (topics.archetype <> 'private_message') AND "topics"."visible" = TRUE AND (topics.category_id IS NULL OR topics.category_id IN (SELECT id FROM categories WHERE NOT read_restricted OR id IN (1,3,6,100,141,202,229,233,235,248,262,594,595,609))) AND "posts"."user_id" = 643476 AND (post_number > 1) ORDER BY posts.like_count DESC, posts.created_at DESC LIMIT 6;
Took 6248.3 ms
SELECT "topic_links"."id" AS t0_r0, "topic_links"."topic_id" AS t0_r1, "topic_links"."post_id" AS t0_r2, "topic_links"."user_id" AS t0_r3, "topic_links"."url" AS t0_r4, "topic_links"."domain" AS t0_r5, "topic_links"."internal" AS t0_r6, "topic_links"."link_topic_id" AS t0_r7, "topic_links"."created_at" AS t0_r8, "topic_links"."updated_at" AS t0_r9, "topic_links"."reflection" AS t0_r10, "topic_links"."clicks" AS t0_r11, "topic_links"."link_post_id" AS t0_r12, "topic_links"."title" AS t0_r13, "topic_links"."crawled_at" AS t0_r14, "topic_links"."quote" AS t0_r15, "topic_links"."extension" AS t0_r16, "topics"."id" AS t1_r0, "topics"."title" AS t1_r1, "topics"."last_posted_at" AS t1_r2, "topics"."created_at" AS t1_r3, "topics"."updated_at" AS t1_r4, "topics"."views" AS t1_r5, "topics"."posts_count" AS t1_r6, "topics"."user_id" AS t1_r7, "topics"."last_post_user_id" AS t1_r8, "topics"."reply_count" AS t1_r9, "topics"."featured_user1_id" AS t1_r10, "topics"."featured_user2_id" AS t1_r11, "topics"."featured_user3_id" AS t1_r12, "topics"."avg_time" AS t1_r13, "topics"."deleted_at" AS t1_r14, "topics"."highest_post_number" AS t1_r15, "topics"."image_url" AS t1_r16, "topics"."like_count" AS t1_r17, "topics"."incoming_link_count" AS t1_r18, "topics"."category_id" AS t1_r19, "topics"."visible" AS t1_r20, "topics"."moderator_posts_count" AS t1_r21, "topics"."closed" AS t1_r22, "topics"."archived" AS t1_r23, "topics"."bumped_at" AS t1_r24, "topics"."has_summary" AS t1_r25, "topics"."archetype" AS t1_r26, "topics"."featured_user4_id" AS t1_r27, "topics"."notify_moderators_count" AS t1_r28, "topics"."spam_count" AS t1_r29, "topics"."pinned_at" AS t1_r30, "topics"."score" AS t1_r31, "topics"."percent_rank" AS t1_r32, "topics"."subtype" AS t1_r33, "topics"."slug" AS t1_r34, "topics"."deleted_by_id" AS t1_r35, "topics"."participant_count" AS t1_r36, "topics"."word_count" AS t1_r37, "topics"."excerpt" AS t1_r38, "topics"."pinned_globally" AS t1_r39, "topics"."pinned_until" AS t1_r40, "topics"."fancy_title" AS t1_r41, "topics"."highest_staff_post_number" AS t1_r42, "topics"."featured_link" AS t1_r43, "topics"."reviewable_score" AS t1_r44, "posts"."id" AS t2_r0, "posts"."user_id" AS t2_r1, "posts"."topic_id" AS t2_r2, "posts"."post_number" AS t2_r3, "posts"."raw" AS t2_r4, "posts"."cooked" AS t2_r5, "posts"."created_at" AS t2_r6, "posts"."updated_at" AS t2_r7, "posts"."reply_to_post_number" AS t2_r8, "posts"."reply_count" AS t2_r9, "posts"."quote_count" AS t2_r10, "posts"."deleted_at" AS t2_r11, "posts"."off_topic_count" AS t2_r12, "posts"."like_count" AS t2_r13, "posts"."incoming_link_count" AS t2_r14, "posts"."bookmark_count" AS t2_r15, "posts"."avg_time" AS t2_r16, "posts"."score" AS t2_r17, "posts"."reads" AS t2_r18, "posts"."post_type" AS t2_r19, "posts"."sort_order" AS t2_r20, "posts"."last_editor_id" AS t2_r21, "posts"."hidden" AS t2_r22, "posts"."hidden_reason_id" AS t2_r23, "posts"."notify_moderators_count" AS t2_r24, "posts"."spam_count" AS t2_r25, "posts"."illegal_count" AS t2_r26, "posts"."inappropriate_count" AS t2_r27, "posts"."last_version_at" AS t2_r28, "posts"."user_deleted" AS t2_r29, "posts"."reply_to_user_id" AS t2_r30, "posts"."percent_rank" AS t2_r31, "posts"."notify_user_count" AS t2_r32, "posts"."like_score" AS t2_r33, "posts"."deleted_by_id" AS t2_r34, "posts"."edit_reason" AS t2_r35, "posts"."word_count" AS t2_r36, "posts"."version" AS t2_r37, "posts"."cook_method" AS t2_r38, "posts"."wiki" AS t2_r39, "posts"."baked_at" AS t2_r40, "posts"."baked_version" AS t2_r41, "posts"."hidden_at" AS t2_r42, "posts"."self_edits" AS t2_r43, "posts"."reply_quoted" AS t2_r44, "posts"."via_email" AS t2_r45, "posts"."raw_email" AS t2_r46, "posts"."public_version" AS t2_r47, "posts"."action_code" AS t2_r48, "posts"."image_url" AS t2_r49, "posts"."locked_by_id" AS t2_r50 FROM "topic_links" INNER JOIN "topics" ON ("topics"."deleted_at" IS NULL) AND "topics"."id" = "topic_links"."topic_id" INNER JOIN "posts" ON ("posts"."deleted_at" IS NULL) AND "posts"."id" = "topic_links"."post_id" WHERE (posts.post_type IN (1,2,3,4)) AND ("topics"."deleted_at" IS NULL) AND (topics.archetype <> 'private_message') AND "topics"."visible" = TRUE AND (topics.category_id IS NULL OR topics.category_id IN (SELECT id FROM categories WHERE NOT read_restricted OR id IN (1,3,6,100,141,202,229,233,235,248,262,594,595,609))) AND "topic_links"."user_id" = 643476 AND "topic_links"."internal" = FALSE AND "topic_links"."reflection" = FALSE AND "topic_links"."quote" = FALSE ORDER BY clicks DESC, topic_links.created_at DESC LIMIT 6;
Took 258.3 ms
SELECT acting_user_id, COUNT(*) FROM "user_actions" INNER JOIN "topics" ON ("topics"."deleted_at" IS NULL) AND "topics"."id" = "user_actions"."target_topic_id" INNER JOIN "posts" ON ("posts"."deleted_at" IS NULL) AND "posts"."id" = "user_actions"."target_post_id" WHERE ("topics"."deleted_at" IS NULL) AND (topics.archetype <> 'private_message') AND "topics"."visible" = TRUE AND (topics.category_id IS NULL OR topics.category_id IN (SELECT id FROM categories WHERE NOT read_restricted OR id IN (1,3,6,100,141,202,229,233,235,248,262,594,595,609))) AND "user_actions"."user_id" = 643476 AND "user_actions"."action_type" = 2 GROUP BY "user_actions"."acting_user_id" ORDER BY COUNT(*) DESC LIMIT 6;
Took 245.5 ms
SELECT user_actions.user_id, COUNT(*) FROM "user_actions" INNER JOIN "topics" ON ("topics"."deleted_at" IS NULL) AND "topics"."id" = "user_actions"."target_topic_id" INNER JOIN "posts" ON ("posts"."deleted_at" IS NULL) AND "posts"."id" = "user_actions"."target_post_id" WHERE ("topics"."deleted_at" IS NULL) AND (topics.archetype <> 'private_message') AND "topics"."visible" = TRUE AND (topics.category_id IS NULL OR topics.category_id IN (SELECT id FROM categories WHERE NOT read_restricted OR id IN (1,3,6,100,141,202,229,233,235,248,262,594,595,609))) AND "user_actions"."action_type" = 2 AND "user_actions"."acting_user_id" = 643476 GROUP BY "user_actions"."user_id" ORDER BY COUNT(*) DESC LIMIT 6;
Took 277.2 ms
SELECT replies.user_id, COUNT(*) FROM "posts" INNER JOIN "topics" ON ("topics"."deleted_at" IS NULL) AND "topics"."id" = "posts"."topic_id" JOIN posts replies ON posts.topic_id = replies.topic_id AND posts.reply_to_post_number = replies.post_number WHERE ("posts"."deleted_at" IS NULL) AND (posts.post_type IN (1,2,3,4)) AND ("topics"."deleted_at" IS NULL) AND (topics.archetype <> 'private_message') AND "topics"."visible" = TRUE AND (topics.category_id IS NULL OR topics.category_id IN (SELECT id FROM categories WHERE NOT read_restricted OR id IN (1,3,6,100,141,202,229,233,235,248,262,594,595,609))) AND "posts"."user_id" = 643476 AND (replies.user_id <> 643476) GROUP BY replies.user_id ORDER BY COUNT(*) DESC LIMIT 6;
Took 3064.6 ms
SELECT category_id FROM "posts" INNER JOIN "topics" ON ("topics"."deleted_at" IS NULL) AND "topics"."id" = "posts"."topic_id" WHERE ("posts"."deleted_at" IS NULL) AND (posts.post_type IN (1,2,3,4)) AND ("topics"."deleted_at" IS NULL) AND (topics.archetype <> 'private_message') AND "topics"."visible" = TRUE AND (topics.category_id IS NULL OR topics.category_id IN (SELECT id FROM categories WHERE NOT read_restricted OR id IN (1,3,6,100,141,202,229,233,235,248,262,594,595,609))) AND "posts"."user_id" = 643476 GROUP BY topics.category_id ORDER BY COUNT(*) DESC LIMIT 6;
Took 2283.3 ms
SELECT category_id, COUNT(*) FROM "posts" INNER JOIN "topics" ON ("topics"."deleted_at" IS NULL) AND "topics"."id" = "posts"."topic_id" WHERE ("posts"."deleted_at" IS NULL) AND (posts.post_type IN (1,2,3,4)) AND ("topics"."deleted_at" IS NULL) AND (topics.archetype <> 'private_message') AND "topics"."visible" = TRUE AND (topics.category_id IS NULL OR topics.category_id IN (SELECT id FROM categories WHERE NOT read_restricted OR id IN (1,3,6,100,141,202,229,233,235,248,262,594,595,609))) AND "posts"."user_id" = 643476 AND (post_number > 1) AND (topics.category_id in (64,13,59,124,327,122)) GROUP BY topics.category_id ORDER BY COUNT(*) DESC;
Took 811.5 ms
I assume Azure has some sort of database statistics for the hosted service, you gotta check those and evaluate what need to change.
Also check the /sidekiq URL on your install to see if there is no queue contention keeping the database busy.
That’s what we’ve checked first. Our instance has
  • 8 cores (~16.18% utilisation, spikes to 60%)
  • 40GB RAM (~60% used, no spiking)
  • 2244 available IOPS (~2.5% utilisation, spikes to 24%)
As said, we’ve used the configuration described in your postgres.10.template.yml . Everything else is at its default. Seems we should take another look into it.
Sidekiq is looking good at the moment. 0 busy, 0 enqueued, 0 retries, 1 scheduled, 0 dead. Job-list is currently empty.
So to come up with a first conclusion. At first we’ll check the postgresql-config as there are some tweaks we could apply. If it won’t work we should consider to upgrade the postgressql-instance and/or perform a full vacuum.
Thanks for your time so far and have a pleasant weekend!
Kind Regards
Sascha
If you have 40GB RAM on the machine, the defaults in the postgres.10.template.yml are no longer appropriate, as samples/standalone.yml points out:
https://github.com/discourse/discourse_docker/blob/master/samples/standalone.yml#L28-L35
Hi,
thanks for your reply. There are some limitations using a PostgreSQL - Instance on Azure. You can’t set some settings like effective_cache_size, max_connections, maintenance_worker_mem or shared_buffers.
At the time of writing this support-request we’ve used the “General Purpose” - Tier which gave us the 40GB RAM but only 1GB of shared_buffers and 2.5GB of effective_cache_size.
Since yesterday we’ve switched to “Memory Optimized” which doubled the RAM to 80GB, 2GB shared_buffers and 5GB effective_cache_size.
work_mem, as a setting we are able to adjust, is currrently set to 128MB as we have no temporary file entries in our logs.
The interesting thing was that as soon as we switched the tier, CPU and IOPS utilisation dropped without increasing the vCores and storage. So we definitely had a problem caused by caches and buffers which were to small.
We still have long loading times showing summary-pages of some users (especially staff-users/long-term users) or the about - page but it’s way better than before (~50% of the prior loading times).
Kind Regards
P.S.
For those who are facing similar issues and have more control over their postgresql installation may these small guides could be helpful:
https://wiki.postgresql.org/wiki/Tuning_Your_PostgreSQL_Server
Architecture and Tuning of Memory in PostgreSQL Databases | Severalnines
Good to hear. Next steps would be to see if you can get away with using a 4vCPU Memory-Optimized as a price optimization, or switch to running it yourself.
Oh, we’re running 8 vCores which results in 80GB ram. shared_buffers are at 2GB but should be at 16GB for this tier and vcore- count. But we’re in touch with the Azure Support to get that fixed.
P.S.
We’re already on 16GB share_buffer. I’ve misinterpreted the output of SELECT * FROM pg_settings WHERE name = 'shared_buffers';. Unit is 8kb.
So I think this topic can be closed. I thank you all for your effort and hope we can achieve some better performance in the next days together with the azure support.
P.P.S.
Sorry @riking, I got you wrong. I think we are good to go with 8 vCores instead of decreasing it to 4. May we give it a try as soon as we’ve achieved the performance we’re after.
