Lounge permissions reset
(Adnan) #1
I noticed that the category permissions resets after updating discourse. I had created a new group and set the permission of the category, but after updating discourse it reverted permissions back to “admin” only group.
Has anyone else encountered this issue? I will try and re-produce the bug and provide some screenshots.
(cpradio) #2
Was it for the Lounge? If so, this is by design and it is encouraged to delete the Lounge and create a new category for your specific permission group instead.
(Adnan) #3
Yes, it was for lounge. Oh k…I will try that instead, thanks for pointing that out.
(Kane York) #4
Note that the “Staff” category also gets these resets (I think). In general, you should try not to repurpose the seeded categories and just make new ones instead.
(Adnan) #5
k, that makes sense. Thanks!
This topic can be closed, since this is not a bug.
(Kane York) #6
This topic was automatically closed after 6 hours. New replies are no longer allowed.
