Mailgun setup with OVH VPS - problem
(DjCyry) #1
Hi ,
I have move my website to a ovh vps ssd 2
I have install it , and everything is ok but the mailgun configuration
is not working , i have also setup the txt , cname , mx on ovh dns settings :
Anyone whos working with ovh can help me ? thanks
(DjCyry) #2
Its works now , was taking 3/4 days to update . :sweat:
#3
In the CNAME config you added, you must use mailgun.org. with the dot at the end. I think it might be the reason it didn’t work well.
It took me less than an hour minutes on my 3 installs on OVH
