MailJet Discourse Mail not being received
Hi,
So I have setup my discourse server and I am attempting to register the admin user but I don’t receive the email I have run discourse doctor and I get this:
./launcher: line 228: /1024**3 < 5: syntax error: operand expected (error token is "/1024**3 < 5")
Anyone know what it means?
Also in mail jet I have verified my domain
I am using port 587
The address I setup for admin is webmaster@ariops.org.uk
I ran tail shared/standalone/log/rails/production.log
Got this:
    Delivered mail 041d1c62-eeba-4323-bc7b-b91b5c5ead7d@community.ariops.org.uk (30012.4ms)
Job exception: execution expired
  Rendering layouts/email_template.html.erb
  Rendered layouts/email_template.html.erb (Duration: 0.2ms | Allocations: 20)
Delivered mail 7eed2494-1804-44c5-8fb5-70527880f4fb@community.ariops.org.uk (30005.3ms)
  Rendered layouts/email_template.html.erb (Duration: 0.1ms | Allocations: 20)
alpine-ariops-discourse:/var/discourse# ./launcher enter app
stat: unrecognized option: format=%a*%S
BusyBox v1.31.1 () multi-call binary.
Usage: stat [OPTIONS] FILE...
Display file (default) or filesystem status
        -c FMT  Use the specified format
        -f      Display filesystem status
        -L      Follow links
        -t      Terse display
FMT sequences for files:
 %a     Access rights in octal
 %A     Access rights in human readable form
 %b     Number of blocks allocated (see %B)
 %B     Size in bytes of each block reported by %b
 %d     Device number in decimal
 %D     Device number in hex
 %f     Raw mode in hex
 %F     File type
 %g     Group ID
 %G     Group name
 %h     Number of hard links
 %i     Inode number
 %n     File name
 %N     File name, with -> TARGET if symlink
 %o     I/O block size
 %s     Total size in bytes
 %t     Major device type in hex
 %T     Minor device type in hex
 %u     User ID
 %U     User name
 %x     Time of last access
 %X     Time of last access as seconds since Epoch
 %y     Time of last modification
 %Y     Time of last modification as seconds since Epoch
 %z     Time of last change
 %Z     Time of last change as seconds since Epoch
FMT sequences for file systems:
 %a     Free blocks available to non-superuser
 %b     Total data blocks
 %c     Total file nodes
 %d     Free file nodes
 %f     Free blocks
 %i     File System ID in hex
 %l     Maximum length of filenames
 %n     File name
 %s     Block size (for faster transfer)
 %S     Fundamental block size (for block counts)
 %t     Type in hex
 %T     Type in human readable form
root@alpine-ariops-discourse-app:/var/www/discourse#
Any Ideas as far as I am aware SPF and DKIM are correctly setup in Cloudflare
Looks like a syntax error on line 228? Perhaps your version of Linux is somehow incompatible with the launcher script. What distribution and version?
Alpine linux 3.11
Solutions to resolve
The easy solution is to use Debian (which CDCK uses) or Ubuntu (which they used to use and is also supported).
Maybe Alpine is somehow using busybox rather than bash? This would be surprising because ./launcher starts with #!/usr/bin/env bash; did you change that line in ./launcher? Did you install bash?
