Maintaining aspect ratio on uploaded image lightbox thumbnails?
(Clay Heaton) #1
We’re having an issue where screenshots from iOS devices embed into a lightbox with appropriate thumbnail dimensions but screenshots from Android devices don’t. I’m wondering if there’s a way to get the Android screenshots to embed appropriately.
For example, here is a screenshot from an iPhone 6s:
and here is one from a Samsung Galaxy 8:
I’m guessing the metadata in the Android image is causing a problem? Is this a bug?
(Jeff Atwood) #2
Not a bug, extremely tall images are cropped in the thumbnail because otherwise they look insane. To see the full image click or tap through.
(Clay Heaton) #3
Thanks, Jeff. Is there a setting that will maintain the long images? For our use case, we’d prefer to see the whole image.
#4
Pushing the max image height setting to 3000 px or more should work (then “rebuild html” your post)
(Clay Heaton) #5
Thanks. I gave that a quick test and ended up with some weird off-aspect squished image. I’ll play around with it more tomorrow.
