# Managing Components / Themes UX feedback
**URL:** https://meta.discourse.org/t/managing-components-themes-ux-feedback/358156
**Category:** UX
**Created:** [March 20, 2025, 1:55pm UTC](https://meta.discourse.org/t/managing-components-themes-ux-feedback/358156 "2025-03-20T13:55:06Z")
**Posts on this page:** 4
**Page:** 1
<div class="post-metadata">
### Author: ![alltiagocom](https://sea3.discourse-cdn.com/meta/user_avatar/meta.discourse.org/alltiagocom/32/492709_2.png) [@alltiagocom](https://meta.discourse.org/u/alltiagocom)
#### Post date: [March 20, 2025, 1:55pm UTC](https://meta.discourse.org/t/managing-components-themes-ux-feedback/358156/1 "2025-03-20T13:55:06Z")
</div>
These boxes for the Component and Theme should go first on the list, not the bottom:
 ![image](https://global.discourse-cdn.com/meta/original/4X/5/d/2/5d21901489ac0523e63c9960310e09c45cd8d8f8.png)
If I have dozens or hundreds of components, I have to scroll all the way down if I want to install a new one. It makes more sense if it’s at the very first position like this:
 ![image](https://global.discourse-cdn.com/meta/original/4X/5/4/6/546066b2926749665cf442fdac9fcdfc3b18c30a.png)
Also, do we really need all that space with the geometric shapes if they are not doing anything? I don’t know if the developers can change this, but so far all the components I installed, have the same image. And do we really need a sub menu for the extra options? Instead of this:
 ![image](https://global.discourse-cdn.com/meta/original/4X/9/3/8/938723d5e13cff773a0b03ab21287113477f59d2.png)
why not this for less clutter, fewer clicks?
 ![image](https://global.discourse-cdn.com/meta/original/4X/6/3/4/634e18b4c2973a16b3da546d7d52d0dd1c7525b3.png)
### Author: ![awesomerobot](https://sea3.discourse-cdn.com/meta/user_avatar/meta.discourse.org/awesomerobot/32/142900_2.png) [@awesomerobot](https://meta.discourse.org/u/awesomerobot)
#### Post date: [March 20, 2025, 1:57pm UTC](https://meta.discourse.org/t/managing-components-themes-ux-feedback/358156/2 "2025-03-20T13:57:10Z")
</div>
If you update Discourse again, this layout has been reverted for now — it wasn’t final and it needs some more work due to some of the issues you’ve mentioned.
### Author: ![Canapin](https://sea3.discourse-cdn.com/meta/user_avatar/meta.discourse.org/canapin/32/119591_2.png) [@Canapin](https://meta.discourse.org/u/Canapin)
#### Post date: [March 20, 2025, 1:57pm UTC](https://meta.discourse.org/t/managing-components-themes-ux-feedback/358156/3 "2025-03-20T13:57:41Z")
</div>
> [@alltiagocom](#):
The more themes and components you have, the less likely you are to install new ones 😛
> [@alltiagocom](#):
This page design is new, was reverted recently (it should be gone if you rebuild), and is currently worked on:
> [@New themes & components layout](https://meta.discourse.org/t/new-themes-components-layout/357320/23):
> Thanks for the feedback here everyone! We’re actively working on improving the theme and component selection pages, and your feedback here is very helpful. For the time being, we’re rolling back these changes while we continue to work on the new interfaces. We’re confident that when we’re finished with these, the new pages will be much more user-friendly and attractive than the current interface. For those interested, here’s the PR for the rollback of the new UI, while we continue to work on i…
#### Post date: [March 20, 2025, 3:10pm UTC](https://meta.discourse.org/t/managing-components-themes-ux-feedback/358156/4 "2025-03-20T15:10:19Z")
</div>
> [@Canapin](#):
Sure, but still, even with just 5 (using the old version), it’s best to have it at the top to avoid scrolling if all I want is to install a new component or theme.
I just updated and I shared some notes here:
> [@New themes & components layout](https://meta.discourse.org/t/new-themes-components-layout/357320/30):
> Why this whole gap in the middle, along with the (imo) unnecessary block on the right? Inspecting the page I see that the block on the left is only taking 28% of the width. Why not 100%? And all the info on the right, along with the install button (why do we have 2 on the same page?) can go to the left, above the box (with the appropriate spacing, of course): Also, if you notice, the box on the right still says “theme(s)” even though I’m in the Components page. A…
