Manually edit sso fields
(Danny Dulai) #1
Is there a way to manually edit the external id?
post sso-migration, i have users in my system that ended up with bad mappings… i can fix it by hand, but id need to change the external id.
rails console or even modifying postgres tables would be acceptable options.
(Jeff Atwood) #2
Looks like a question for @sam?
(Sam Saffron) #3
You can do it from the rails console, will update with instructions some time tomorrow
(Sam Saffron) #4
This should work
./launcher enter app
rails c
> u = User.find_by_username('sam').single_sign_on_record
> u.external_id = "foo"
> u.save!
