Markdown formatting I came across that doesn't work "right"
(Michael Brown) #1
variant one
1. List item
1. Commented block below
1. Commented item 1
1. Commented item 2
1. Another list item
  1. List item
  2. Commented block below
  1. Another list item (should be numeric, not bullet)
variant two
1. List item
1. Commented item 1
Commented item 2 (non-list)
  1. List item
  1. Another list item (which should be 3)
and this is for @eviltrout:
(Jeff Atwood) #2
Did you test them on babelmark?
I don’t think you did, because case #2 is invalid. Case #1 looks like a valid complaint, however.
I wish the source library we used had tested itself against the standard MDTest suite… here’s the input files to be verified against standard output files…
(Michael Brown) #3
I hadn’t even known that existed.
Interesting results removing the spaces - seems to confuse a lot of parsers:
1. List item
1. Commented item 1
1. Commented item 2
But ours handles it right:
  1. List item
But if we change what’s inside the commented block, it gets odd:
1. List item
1. Commented item 1
1. Commented item 2
  1. List item
1. List item
1. Commented item 1
1. Commented item 2
  1. List item
(Jeff Atwood) #4
Looks correct now. In your first example where it says “should be numeric, not bullet” is indeed a number. And the second example isn’t really valid.
(Jeff Atwood) #5
