Markdown headers not working as before
(Lars Zimmermann) #1
Hi
since we updated to the last version v2.0.0.beta3 +36 our whole forum with thousands of topics looks now a bit weird because the markdown does not work like before. It requires now a space between the # and the text to transform it into a headline. It was not like that before and almost all of our topics look now like this:
IMAGE:
46
This is really a problem.
Also adding html does not seem to work anymore which also makes a lot of our old topics with important info look weird now.
Any suggestions how to fix this?
All the best,
lars
(cpradio) #2
See The #Header markdown syntax stop working
As for the HTML markup, can you provide examples?
(Lars Zimmermann) #3
Mmh. Thanks for the link. Well for us it is not “rare affected posts” - fixing by hand will require quite some work – where to start? We have also created a bunch of resources like videos teaching ppl. how to use the forum and it is all broke now. We are a voluntary project with limited resources. And this is a bummer :frowning:
And for the html part:
I used to write
15
to get more space between the lines. Which is not working anymore.
Also centering things with similar code is not working anymore.
And here is another problem: This is a screenshot from our forum. It used to be a solid grey block. And now it looks like this. Not just on this topic which is a key topic on our forum:
SCREENSHOT
So if you know a way to fix this, it would be really helpful.
(cpradio) #4
Discourse switched to the actual standard, CommonMark, which changed some of the parsing, as such, older topics can/might have some issues.
For uses of <div> and centering text, you likely need to install/modify the Formatting toolbar plugin, it will give you additional HTML components you can use.
Sadly, I don’t really see many other options than doing a global find a replace to fix situations that broke, such as, the headers and maybe that quoteblock.
(Lars Zimmermann) #5
And record a new video for all our not tech savvy users (the video has several views per day)
… and all the other stuff
:frowning:
ok
If someone of you happen to know why these changes were necessary I would be curious. It would help to deal with the consequences.
(Michael Friedrich) #6
GitHub also has that problem, you can find a lot of repositories where the documentation isn’t rendered properly. I wasn’t aware that a non-space was even possible though.
How about some SQL and sed magic then? If #([\w+\s+]*) matches and extracts, replace it with whitespaces and extracted string.
