Markdown links with ... in the text
(Neil Lalonde) #1
This link doesn’t get cooked into html very well…
[http://www.google.com ... wat](http://www.discourse.org)
This creates a link to google, a link to discourse.org url that can’t be clicked, and renders " … wat" after the links:
<a href="http://www.discourse.org"></a>
<a href="http:///www.google.com">http://www.google.com</a>
... wat
This is annoying because phpBB shortens links exactly like that, so all those links are broken after an import.
(Sam Saffron) #2
Pandoc and pagedown are good here:
Babelmark 2 - Compare markdown implementations…+wat%5D(http%3A%2F%2Fwww.discourse.org)
Should a fairly straight forward fix I think.
(Jeff Atwood) #3
[http://www.google.com...wat](http://www.discourse.org)
http://www.google.com…wat
Maybe collapse it for now? Just remove the spaces as a workaround.
(Jeff Atwood) #4
@eviltrout this needs a fix Monday since it is kind of blocking phpbb imports a little.
(Neil Lalonde) #5
It’s not blocking anymore. If the http://(www\.)? is stripped, it works even with the extra spaces around ....
(Robin Ward) #6
Fixed here:
https://github.com/discourse/discourse/commit/1886ffaff2e51a2296480c8c1cf42dd8bdb05238
(Jeff Atwood) #7
