Markdown parser unable to parse blockquote if there's space before <
markdown
(Aahan Krish) #1
For example (notice the space before the >):
 > Hello, this is a blockquote.
Results in:
(Confirmed with markdown dingus.)
Although nothing to prioritize, this is another edge case (probably) that the markdown parser misses. @eviltrout :trollface:
(Konrad Borowski) #2
While I don’t think space before > is common, there is use case where it could feasibly happen. This works fine in real Markdown.
> Line 1
>  > Line 2
Line 1
Line 2
(Jeff Atwood) #3
Yes that should absolutely be working! @eviltrout?
(Jeff Atwood) #4
I believe this is now fixed, can you verify @eviltrout?
(Robin Ward) #5
Definitely fixed now, thanks for reporting it.
(Robin Ward) #6
