Marking closed topic solved with solve_topics_auto_close_hours set causes topic to be reopened
(Joshua Rosenfeld) #1
Just set solved topics auto close hours on one of my sites. Ran into an issue when a moderator marked a closed topic solved. The topic was re-opened. This was quite unexpected, and caused a year old topic to resurface to the top of the /latest. If a topic is already closed, marking a post as the solution should not cause the topic to re-open.
(Joshua Rosenfeld) #2
I’m usually not this quick to ask “any progress” on a report - but this has become a real issue on my site. We really like the auto-close timer - but reopening closed topics is really bad!!! I’m going to try and dig into the code for this, but I’d really appreciate some help. To me this is #bug.
(Joshua Rosenfeld) #3
OK…so I think this is the line I need to modify:
I don’t know ruby, so it’s going to take some googling but I think I just want to do something like this:
if (auto_close_hours = SiteSetting.solved_topics_auto_close_hours) > 0 and topic !closed
(David Taylor) #4
That looks almost right to me. I think the syntax should be:
and !topic.closed
(Joshua Rosenfeld) #5
Would that be valid ruby if just tacked onto the end? Or do I need to surround the first clause of the if statement with parenthesis? Not sure what the order of operations is in Ruby.
(David Taylor) #6
Think what you’ve got should be fine - ! and > have higher precedence than and
https://ruby-doc.org/core-2.2.0/doc/syntax/precedence_rdoc.html
(Joshua Rosenfeld) #7
Wonderful, thanks @david!
PR submitted:
(Joshua Rosenfeld) #8
So… @zogstrip said a test is needed before he can merge it. Besides not knowing Ruby - I’ve never had to write a test before. I’m going to start looking at other plugins, but help would be appreciated.
Aside: it really is awful how “theoretical” most CS degrees are. I can talk all about algorithms, but when it comes to practical stuff like version control, or tests - wish me luck!
(Régis Hanol) #9
Look at how that file is tested and use another test as starting point :wink:
(Joshua Rosenfeld) #10
Yep - I see the existing test, and I understand the basic structure…currently trying to find a test that deals with an open/closed topic.
(Joshua Rosenfeld) #11
OK. So does this work?
I’m thinking something like:
require 'rails_helper'
RSpec.describe "Managing Posts solved status" do
  let(:topic) { Fabricate(:topic) }
  let(:topic2) { Fabricate(:topic) } # Make a second topic
  let(:user) { Fabricate(:trust_level_4) }
  let(:p1) { Fabricate(:post, topic: topic) }
  let(:p2) { Fabricate(:post, topic: topic2) } # Add a post to the second topic
# previous test:
  before do
    SiteSetting.allow_solved_on_all_topics = true
  describe 'accepting a post as the answer' do
    before do
      sign_in(user)
      SiteSetting.solved_topics_auto_close_hours = 2
    it 'can mark a post as the accepted answer correctly' do
      xhr :post, "/solution/accept", id: p1.id
      expect(p1.reload.custom_fields["is_accepted_answer"]).to eq("true")
      expect(topic.public_topic_timer.status_type).to eq(TopicTimer.types[:close])
      expect(topic.public_topic_timer.execute_at)
        .to be_within(1.second).of(Time.zone.now + 2.hours)
      expect(topic.public_topic_timer.based_on_last_post).to eq(true)
# end of previous test
    it 'does not set a timer when the topic is closed' do
      topic2.update!(closed: true)
      xhr :post, "/solution/accept", id: p2.id
      expect(p2.reload.custom_fields["is_accepted_answer"]).to eq("true")
      expect(topic2.reload.public_topic_timer).to eq(nil)
      expect(topic2.reload.closed).to eq(true)
(Joshua Rosenfeld) #12
I’ve added this spec to the PR. Hopefully this is in fact what @zogstrip was looking for…
Edit: and this is merged! Thanks @zogstrip for your help. Régis did bring up a concern about archived topics, but I’m not sure how topic timers affect archived topics. Trying to test on my dev instance, but I’m running into issues getting it updated.
