MathJax or Discourse Issue?
(Markus) #1
I have two Discourse installations on different servers. One of them is showing me a white/blank page if MathJax is enabled. The other one doesn’t. The only difference between both installations is, that the other one hasn’t installed the latest 12 official commits. Have a look…
How can I fix this? Unfortunately, I really need LaTeX support on this page. It’s essential.
Thanks in advance!!!
Kind regards
Server #1 (with blank page, if MathJax is enabled)
Server #2 (without blank page, if MathJax is enabled)
The latest 12 commits:
(Sam Saffron) #2
what is the error, something is going to be showing up in console
(Markus) #3
On rebuild, everything on console looks fine. What log’s you’re looking for?
(Sam Saffron) #4
This console:
(Markus) #5
(Sam Saffron) #6
yeah @eviltrout removed that the other day, the plugin needs to use the new script loader
https://github.com/discourse/discourse/commit/de4e4f2b986ff30bf5e9da73066c754a70f9b61c
@Kasper this is quite urgent, maybe polyfill it in the plugin if you need backwards support.
Robin we should deprecate $LAB as opposed to straight removing it.
(Markus) #7
Hopefully, someone at the MathJax team (@Kasper) is caring about this issue too.
(Kasper Peulen) #8
I’m not from the MathJax team :smile: But I will look at it when I have my laptop back tomorrow.
So basicly I need to replace $LAB for loadscript, except if $LAB is still defined ?
(Robin Ward) #9
I didn’t even think that plugins might be using it. I’ll add back in a deprecation today.
(Markus) #10
It’s still not working under fb85d3c. :confused:
Update: Ahh ok, the latest commit wasn’t pulled. I’ll wait some time…
(Robin Ward) #11
That’s because that commit didn’t include my deprecation! You gotta give me more than 30 mins to get it done :smile:
This commit in Discourse puts back a mock $LAB object with deprecation warning that allows the plugin to work:
I also made a PR to Mathjax to update to the latest API so this isn’t needed.
(Kasper Peulen) #12
Okay, request pulled. Thanks @eviltrout really appreciated :beer:
(Markus) #13
Yeeeeesss. It’s working again. :beers:
