Message auto-reported by the system
(Axel Briche) #1
Hello, I have update my Discourse installation, and since when a user create a thread, the thread and the message are hidden and repported by the System:
Have you a solution for fix this problem please ? It’s a bug of Discourse or a problem with the configuration please ?
Thanks for your help.
Axel.
(Régis Hanol) #2
Can I have access to your instance?
(Axel Briche) #3
It’s here: http://forum.yakarouler.com
(Axel Briche) #4
The system auto-repport:
(Axel Briche) #5
Send by PM. Thank you.
(Régis Hanol) #6
Solved! The issue was that the flag sockpuppets site setting was enabled and both users were new and using the same IP address.
(Régis Hanol) #7
