Meta description optimization for posts with image at the beginning
(Spooky) #1
When there is an image at the start of the topic, the meta description of the page has a tag [image] and few spaces at the start of it, can you change it remove the [image] tag and trim the spaces?
(Jeff Atwood) #2
Why? This is correct behavior.
(Spooky) #3
But why the words [image] inside the description. If the image has an alt tag, it’s not go either, becaues I describe what’s in the image, and it might not be related to the topic at all. And if we already use what’s in the alt tag, at least not with the brackets []… Can you please explain why you’ve chosen to add the [image] word (literally [image]) to the description?
