And my vbulletin import script, which does handle non-linked attachments, doesn’t look for them in that table, so you’ll need some custom code to deal with that, even after I get around to submitting a PR with my script.
EDIT: and it also means that I think that even if they were linked in-post they still wouldn’t work, since they aren’t where the script expects them in the database.
Good news! I don’t know exactly how the import script handles it but it does! After making the files accessible to the import container and digging a bit in the script I found that it works. The only problem I had was that the file name which I tested it on contained an ä and thus some weird encoding shit prevented the script from finding the file actually. After fixing the filename the import worked and the attachment appeared at the post!
Awesome! Glad the magic worked for you! (Oh! I and I see now that I was looking at the vBulletin script and not bbPress, hence my confusion. That explains why I couldn’t find the table!)
Hi
I got an error after launching the IMPORT bundle exec command:
Using unicorn 5.5.1
Using webmock 3.7.6
Using webpush 1.0.0
Using yaml-lint 0.0.10
Bundle complete! 130 Gemfile dependencies, 214 gems now installed.
Use `bundle info [gemname]` to see where a bundled gem is installed.
Traceback (most recent call last):
31: from scripts/import_scripts/bbpress.rb:4:in `<main>'
30: from scripts/import_scripts/bbpress.rb:4:in `require'
29: from /var/discourse/scripts/import_scripts/base.rb:16:in `<top (required)>'
28: from /var/discourse/scripts/import_scripts/base.rb:16:in `require_relative'
27: from /var/discourse/config/environment.rb:7:in `<top (required)>'
26: from /home/kenaddams42/.rbenv/versions/2.6.5/lib/ruby/gems/2.6.0/gems/railties-6.0.1/lib/rails/railtie.rb:190:in `method_missing'
25: from /home/kenaddams42/.rbenv/versions/2.6.5/lib/ruby/gems/2.6.0/gems/railties-6.0.1/lib/rails/railtie.rb:190:in `public_send'
24: from /home/kenaddams42/.rbenv/versions/2.6.5/lib/ruby/gems/2.6.0/gems/railties-6.0.1/lib/rails/application.rb:363:in `initialize!'
23: from /home/kenaddams42/.rbenv/versions/2.6.5/lib/ruby/gems/2.6.0/gems/railties-6.0.1/lib/rails/initializable.rb:60:in `run_initializers'
22: from /home/kenaddams42/.rbenv/versions/2.6.5/lib/ruby/2.6.0/tsort.rb:205:in `tsort_each'
21: from /home/kenaddams42/.rbenv/versions/2.6.5/lib/ruby/2.6.0/tsort.rb:226:in `tsort_each'
20: from /home/kenaddams42/.rbenv/versions/2.6.5/lib/ruby/2.6.0/tsort.rb:347:in `each_strongly_connected_component'
19: from /home/kenaddams42/.rbenv/versions/2.6.5/lib/ruby/2.6.0/tsort.rb:347:in `call'
18: from /home/kenaddams42/.rbenv/versions/2.6.5/lib/ruby/2.6.0/tsort.rb:347:in `each'
17: from /home/kenaddams42/.rbenv/versions/2.6.5/lib/ruby/2.6.0/tsort.rb:349:in `block in each_strongly_connected_component'
16: from /home/kenaddams42/.rbenv/versions/2.6.5/lib/ruby/2.6.0/tsort.rb:431:in `each_strongly_connected_component_from'
15: from /home/kenaddams42/.rbenv/versions/2.6.5/lib/ruby/2.6.0/tsort.rb:350:in `block (2 levels) in each_strongly_connected_component'
14: from /home/kenaddams42/.rbenv/versions/2.6.5/lib/ruby/2.6.0/tsort.rb:228:in `block in tsort_each'
13: from /home/kenaddams42/.rbenv/versions/2.6.5/lib/ruby/gems/2.6.0/gems/railties-6.0.1/lib/rails/initializable.rb:61:in `block in run_initializers'
12: from /home/kenaddams42/.rbenv/versions/2.6.5/lib/ruby/gems/2.6.0/gems/railties-6.0.1/lib/rails/initializable.rb:32:in `run'
11: from /home/kenaddams42/.rbenv/versions/2.6.5/lib/ruby/gems/2.6.0/gems/railties-6.0.1/lib/rails/initializable.rb:32:in `instance_exec'
10: from /home/kenaddams42/.rbenv/versions/2.6.5/lib/ruby/gems/2.6.0/gems/railties-6.0.1/lib/rails/application/bootstrap.rb:73:in `block in <module:Bootstrap>'
9: from /home/kenaddams42/.rbenv/versions/2.6.5/lib/ruby/gems/2.6.0/gems/activesupport-6.0.1/lib/active_support/lazy_load_hooks.rb:51:in `run_load_hooks'
8: from /home/kenaddams42/.rbenv/versions/2.6.5/lib/ruby/gems/2.6.0/gems/activesupport-6.0.1/lib/active_support/lazy_load_hooks.rb:51:in `each'
7: from /home/kenaddams42/.rbenv/versions/2.6.5/lib/ruby/gems/2.6.0/gems/activesupport-6.0.1/lib/active_support/lazy_load_hooks.rb:52:in `block in run_load_hooks'
6: from /home/kenaddams42/.rbenv/versions/2.6.5/lib/ruby/gems/2.6.0/gems/activesupport-6.0.1/lib/active_support/lazy_load_hooks.rb:67:in `execute_hook'
5: from /home/kenaddams42/.rbenv/versions/2.6.5/lib/ruby/gems/2.6.0/gems/activesupport-6.0.1/lib/active_support/lazy_load_hooks.rb:62:in `with_execution_control'
4: from /home/kenaddams42/.rbenv/versions/2.6.5/lib/ruby/gems/2.6.0/gems/activesupport-6.0.1/lib/active_support/lazy_load_hooks.rb:69:in `block in execute_hook'
3: from /home/kenaddams42/.rbenv/versions/2.6.5/lib/ruby/gems/2.6.0/gems/ember-rails-0.18.5/lib/ember/rails/engine.rb:19:in `block in <class:Engine>'
2: from /home/kenaddams42/.rbenv/versions/2.6.5/lib/ruby/gems/2.6.0/gems/bootsnap-1.4.5/lib/bootsnap/load_path_cache/core_ext/active_support.rb:59:in `load_missing_constant'
1: from /home/kenaddams42/.rbenv/versions/2.6.5/lib/ruby/gems/2.6.0/gems/bootsnap-1.4.5/lib/bootsnap/load_path_cache/core_ext/active_support.rb:16:in `allow_bootsnap_retry'
/home/kenaddams42/.rbenv/versions/2.6.5/lib/ruby/gems/2.6.0/gems/bootsnap-1.4.5/lib/bootsnap/load_path_cache/core_ext/active_support.rb:60:in `block in load_missing_constant': uninitialized constant Sprockets::Engines (NameError)
32: from scripts/import_scripts/bbpress.rb:4:in `<main>'
31: from scripts/import_scripts/bbpress.rb:4:in `require'
30: from /var/discourse/scripts/import_scripts/base.rb:16:in `<top (required)>'
29: from /var/discourse/scripts/import_scripts/base.rb:16:in `require_relative'
28: from /var/discourse/config/environment.rb:7:in `<top (required)>'
27: from /home/kenaddams42/.rbenv/versions/2.6.5/lib/ruby/gems/2.6.0/gems/railties-6.0.1/lib/rails/railtie.rb:190:in `method_missing'
26: from /home/kenaddams42/.rbenv/versions/2.6.5/lib/ruby/gems/2.6.0/gems/railties-6.0.1/lib/rails/railtie.rb:190:in `public_send'
25: from /home/kenaddams42/.rbenv/versions/2.6.5/lib/ruby/gems/2.6.0/gems/railties-6.0.1/lib/rails/application.rb:363:in `initialize!'
24: from /home/kenaddams42/.rbenv/versions/2.6.5/lib/ruby/gems/2.6.0/gems/railties-6.0.1/lib/rails/initializable.rb:60:in `run_initializers'
23: from /home/kenaddams42/.rbenv/versions/2.6.5/lib/ruby/2.6.0/tsort.rb:205:in `tsort_each'
22: from /home/kenaddams42/.rbenv/versions/2.6.5/lib/ruby/2.6.0/tsort.rb:226:in `tsort_each'
21: from /home/kenaddams42/.rbenv/versions/2.6.5/lib/ruby/2.6.0/tsort.rb:347:in `each_strongly_connected_component'
20: from /home/kenaddams42/.rbenv/versions/2.6.5/lib/ruby/2.6.0/tsort.rb:347:in `call'
19: from /home/kenaddams42/.rbenv/versions/2.6.5/lib/ruby/2.6.0/tsort.rb:347:in `each'
18: from /home/kenaddams42/.rbenv/versions/2.6.5/lib/ruby/2.6.0/tsort.rb:349:in `block in each_strongly_connected_component'
17: from /home/kenaddams42/.rbenv/versions/2.6.5/lib/ruby/2.6.0/tsort.rb:431:in `each_strongly_connected_component_from'
16: from /home/kenaddams42/.rbenv/versions/2.6.5/lib/ruby/2.6.0/tsort.rb:350:in `block (2 levels) in each_strongly_connected_component'
15: from /home/kenaddams42/.rbenv/versions/2.6.5/lib/ruby/2.6.0/tsort.rb:228:in `block in tsort_each'
14: from /home/kenaddams42/.rbenv/versions/2.6.5/lib/ruby/gems/2.6.0/gems/railties-6.0.1/lib/rails/initializable.rb:61:in `block in run_initializers'
13: from /home/kenaddams42/.rbenv/versions/2.6.5/lib/ruby/gems/2.6.0/gems/railties-6.0.1/lib/rails/initializable.rb:32:in `run'
12: from /home/kenaddams42/.rbenv/versions/2.6.5/lib/ruby/gems/2.6.0/gems/railties-6.0.1/lib/rails/initializable.rb:32:in `instance_exec'
11: from /home/kenaddams42/.rbenv/versions/2.6.5/lib/ruby/gems/2.6.0/gems/railties-6.0.1/lib/rails/application/bootstrap.rb:73:in `block in <module:Bootstrap>'
10: from /home/kenaddams42/.rbenv/versions/2.6.5/lib/ruby/gems/2.6.0/gems/activesupport-6.0.1/lib/active_support/lazy_load_hooks.rb:51:in `run_load_hooks'
9: from /home/kenaddams42/.rbenv/versions/2.6.5/lib/ruby/gems/2.6.0/gems/activesupport-6.0.1/lib/active_support/lazy_load_hooks.rb:51:in `each'
8: from /home/kenaddams42/.rbenv/versions/2.6.5/lib/ruby/gems/2.6.0/gems/activesupport-6.0.1/lib/active_support/lazy_load_hooks.rb:52:in `block in run_load_hooks'
7: from /home/kenaddams42/.rbenv/versions/2.6.5/lib/ruby/gems/2.6.0/gems/activesupport-6.0.1/lib/active_support/lazy_load_hooks.rb:67:in `execute_hook'
6: from /home/kenaddams42/.rbenv/versions/2.6.5/lib/ruby/gems/2.6.0/gems/activesupport-6.0.1/lib/active_support/lazy_load_hooks.rb:62:in `with_execution_control'
5: from /home/kenaddams42/.rbenv/versions/2.6.5/lib/ruby/gems/2.6.0/gems/activesupport-6.0.1/lib/active_support/lazy_load_hooks.rb:69:in `block in execute_hook'
4: from /home/kenaddams42/.rbenv/versions/2.6.5/lib/ruby/gems/2.6.0/gems/ember-rails-0.18.5/lib/ember/rails/engine.rb:19:in `block in <class:Engine>'
3: from /home/kenaddams42/.rbenv/versions/2.6.5/lib/ruby/gems/2.6.0/gems/bootsnap-1.4.5/lib/bootsnap/load_path_cache/core_ext/active_support.rb:58:in `load_missing_constant'
2: from /home/kenaddams42/.rbenv/versions/2.6.5/lib/ruby/gems/2.6.0/gems/bootsnap-1.4.5/lib/bootsnap/load_path_cache/core_ext/active_support.rb:79:in `rescue in load_missing_constant'
1: from /home/kenaddams42/.rbenv/versions/2.6.5/lib/ruby/gems/2.6.0/gems/bootsnap-1.4.5/lib/bootsnap/load_path_cache/core_ext/active_support.rb:8:in `without_bootsnap_cache'
/home/kenaddams42/.rbenv/versions/2.6.5/lib/ruby/gems/2.6.0/gems/bootsnap-1.4.5/lib/bootsnap/load_path_cache/core_ext/active_support.rb:79:in `block in load_missing_constant': uninitialized constant Sprockets::Engines (NameError)
root@sd-114000:/var/discourse# ~
After running sudo nano script/import_scripts/bbpress.rb it opens the file editor, but when I tray and save, it says there’s no such file or directory:
In the above guide, I used /var/discourse directory to install the Discourse development environment. If you installed it in a different location then make sure to cd to that directory (’~/discourse’ in most cases) instead of the above before running the sudo nano script/import_scripts/bbpress.rb command.
You’ll need to set up a development environment or follow instructions in other import topics about how you might run the import script inside of a production container.
@vinothkannans I’m trying to migrate from WPForo to Discourse and the script/code is beyond my capability. Would you (or anyone else) be able to help me with this? Thanks.
I’m getting the following error when I follow the guide and get to the point where I run the import script. I installed discourse as per these instructions
myuser@tmp-discourse:~/discourse$ IMPORT=1 bundle && IMPORT=1 bundle exec ruby script/import_scripts/bbpress.rb
[!] There was an error parsing `Gemfile`: You cannot specify the same gem twice with different version requirements.
You specified: sqlite3 (~> 1.3, >= 1.3.13) and sqlite3 (>= 0). Bundler cannot continue.
# from /home/myuser/discourse/Gemfile:251
# group :generic_import, optional: true do
> gem "sqlite3"
# gem "redcarpet"
