Migration 1.8 -> 1.9 errors
(Mathieu Menut) #1
Hello,
I tried to upgrade a Discourse instance from 1.8.10 to 1.9 and… this doesn’t work with a really bad error, linked to Postgres I think. Am I the first to have this? I don’t know for now how to resolve this so if you have some clues to debug it… It can really helps.
I tried to do the update from command line via commands below:
git pull
./launcher rebuild app
Thanks for your help and your work :).
Mathieu.
Log is below:
I, [2018-01-05T17:26:34.986776 #15]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate'
rake aborted!
StandardError: An error has occurred, this and all later migrations canceled:
PG::InternalError: ERROR:  missing chunk number 0 for toast value 2424339 in pg_toast_1700886
: ALTER TABLE "post_search_data" ADD "version" integer DEFAULT 0
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-mini-profiler-0.10.7/lib/patches/db/pg.rb:90:in `async_exec'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/connection_adapters/postgresql/database_statements.rb:73:in `block (2 levels) in execute'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/dependencies/interlock.rb:46:in `block in permit_concurrent_loads'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/concurrency/share_lock.rb:185:in `yield_shares'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/dependencies/interlock.rb:45:in `permit_concurrent_loads'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/connection_adapters/postgresql/database_statements.rb:72:in `block in execute'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/connection_adapters/abstract_adapter.rb:612:in `block (2 levels) in log'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/connection_adapters/abstract_adapter.rb:611:in `block in log'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/notifications/instrumenter.rb:21:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/connection_adapters/abstract_adapter.rb:603:in `log'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/connection_adapters/postgresql/database_statements.rb:71:in `execute'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/connection_adapters/abstract/schema_statements.rb:554:in `add_column'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/connection_adapters/postgresql/schema_statements.rb:409:in `add_column'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/migration.rb:849:in `block in method_missing'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/migration.rb:818:in `block in say_with_time'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/migration.rb:818:in `say_with_time'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/migration.rb:838:in `method_missing'
/var/www/discourse/db/migrate/20170803123704_add_version_to_search_data.rb:3:in `change'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/migration.rb:792:in `exec_migration'
/var/www/discourse/lib/freedom_patches/schema_migration_details.rb:7:in `block in exec_migration'
/var/www/discourse/lib/freedom_patches/schema_migration_details.rb:6:in `exec_migration'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/migration.rb:776:in `block (2 levels) in migrate'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/migration.rb:775:in `block in migrate'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/connection_adapters/abstract/connection_pool.rb:408:in `with_connection'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/migration.rb:774:in `migrate'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/migration.rb:953:in `migrate'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/migration.rb:1230:in `block in execute_migration_in_transaction'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/migration.rb:1298:in `block in ddl_transaction'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/connection_adapters/abstract/database_statements.rb:235:in `block in transaction'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/connection_adapters/abstract/transaction.rb:194:in `block in within_new_transaction'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/connection_adapters/abstract/transaction.rb:191:in `within_new_transaction'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/connection_adapters/abstract/database_statements.rb:235:in `transaction'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/transactions.rb:210:in `transaction'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/migration.rb:1298:in `ddl_transaction'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/migration.rb:1229:in `execute_migration_in_transaction'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/migration.rb:1201:in `block in migrate_without_lock'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/migration.rb:1200:in `each'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/migration.rb:1200:in `migrate_without_lock'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/migration.rb:1148:in `block in migrate'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/migration.rb:1317:in `with_advisory_lock'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/migration.rb:1148:in `migrate'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/migration.rb:1007:in `up'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/migration.rb:985:in `migrate'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/tasks/database_tasks.rb:171:in `migrate'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/railties/databases.rake:58:in `block (2 levels) in <top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rake-12.1.0/exe/rake:27:in `<top (required)>'
/usr/local/bin/bundle:23:in `load'
/usr/local/bin/bundle:23:in `<main>'
ActiveRecord::StatementInvalid: PG::InternalError: ERROR:  missing chunk number 0 for toast value 2424339 in pg_toast_1700886
Tasks: TOP => db:migrate
I, [2018-01-05T17:26:43.632671 #15]  INFO -- : == 20170803123704 AddVersionToSearchData: migrating ===========================
-- add_column(:post_search_data, :version, :integer, {:default=>0})
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate' failed with return #<Process::Status: pid 160 exit 1>
Location of failure: /pups/lib/pups/exec_command.rb:108:in `spawn'
exec failed with the params {"cd"=>"$home", "hook"=>"bundle_exec", "cmd"=>["su discourse -c 'bundle install --deployment --verbose --without test --without development --retry 3 --jobs 4'", "su discourse -c 'bundle exec rake db:migrate'", "su discourse -c 'bundle exec rake assets:precompile'"]}
e9591e2297539d660ee07e404ee4a65a90a410e318c229474443e063bbcd525e
** FAILED TO BOOTSTRAP ** please scroll up and look for earlier error messages, there may be more than one
(Jeff Atwood) #2
Search here for “missing chunk”, it looks like you have a corrupt database.
(Matt Palmer) #3
Yeah, your DB is hosed. How’s your backups?
(Mathieu Menut) #4
Yeah it’s okay! I deleted corrupted data (one line in the Postgres database.).
But now I have another problem when compressing javascript files.
Compressing: docker-manager-app-0a56d906a59c60abc96e07b2366723947c14402527d1be5505b557e7caf7bb12.js
gzip -f -c -9 /var/www/discourse/public/assets/docker-manager-app-0a56d906a59c60abc96e07b2366723947c14402527d1be5505b557e7caf7bb12.js > /var/www/discourse/public/assets/docker-manager-app-0a56d906a59c60abc96e07b2366723947c14402527d1be5505b557e7caf7bb12.js.gz
brotli --quality=11 /var/www/discourse/public/assets/docker-manager-app-0a56d906a59c60abc96e07b2366723947c14402527d1be5505b557e7caf7bb12.js --output=/var/www/discourse/public/assets/docker-manager-app-0a56d906a59c60abc96e07b2366723947c14402527d1be5505b557e7caf7bb12.js.br
failed to open output file [/var/www/discourse/public/assets/docker-manager-app-0a56d906a59c60abc96e07b2366723947c14402527d1be5505b557e7caf7bb12.js.br]: File exists
rake aborted!
brotli compression failed: exit code 1
/var/www/discourse/lib/tasks/assets.rake:140:in `brotli'
/var/www/discourse/lib/tasks/assets.rake:195:in `block (4 levels) in <top (required)>'
/var/www/discourse/lib/tasks/assets.rake:160:in `block in concurrent?'
/var/www/discourse/lib/tasks/assets.rake:185:in `block (3 levels) in <top (required)>'
/var/www/discourse/lib/tasks/assets.rake:174:in `each'
/var/www/discourse/lib/tasks/assets.rake:174:in `block (2 levels) in <top (required)>'
/var/www/discourse/lib/tasks/assets.rake:160:in `concurrent?'
/var/www/discourse/lib/tasks/assets.rake:170:in `block in <top (required)>'
Tasks: TOP => assets:precompile
I, [2018-01-08T14:18:47.928817 #14]  INFO -- : `/root` is not writable.
Bundler will use `/tmp/bundler/home/discourse' as your home directory temporarily.
Purging temp files
Bundling assets
Compressing Javascript and Generating Source Maps
FAILED
Pups::ExecError: cd /var/www/discourse &&  sudo -E -u discourse bundle exec rake assets:precompile failed with return #<Process::Status: pid 3128 exit 1>
exec failed with the params "cd $home &&  sudo -E -u discourse bundle exec rake assets:precompile"
cde39067699ec035cb6f9c6e0cf5e55cf37439df097ce13fd5fcbfbf3aafca3b
(Mathieu Menut) #5
UPDATE:
If it can helps (I don’t know if there is a bug or something else…), I had to delete /var/www/discourse/public/assets/docker-manager-* before trying to bundle exec rake assets:precompile again. Now it seems to work correctly!
(Miguel F) #6
I’m actually experiencing this same error on bundle exec rake assets:precompile, which led me to this thread.
In my case, it was after modifying my app.yml to install a plugin from a private repo as outlined here.
Adding rm -fr public/assets/docker-manager-* before bundle exec rake assets:precompile resolved the issue.
(Mathieu Menut) #7
Yes ! Il sas thé sale for me.
I deleted this module then and will make my updates with command line.
There is definitely a bug with this plugin.
