Min post length - doesn't take effect immediately?
(Dean Taylor) #1
After changing the min post length setting in admin…
… What is required for users to see this change take effect?
####Background
At specific times we have “meetings” at these times in a few topics we find the minimum post length actually hinders conversation.
So when these meetings occur I want to reduce the minimum post length requirement to say 2
…(it would be nice if I could do this per topic or category etc - but it’s not available as an option)…
It seems changing this value doesn’t take effect immediately.
Is a server rebuild / restart required?
Or just that all users need to close browsers and open again?
How to set Minimum Topic Body Length?
(Robin Ward) #2
Rebuild should not be necessary. It should be as simple as having users reload their browsers.
(Sam Saffron) #3
Long term we should probably issue a message to all clients when a client_setting changes asking them to refresh.
(Jeff Atwood) #4
The currently loaded JavaScript in the browser does not know about this change. We don’t expect this is a setting one would be changing every hour on the fly, or even every few days…
(Dean Taylor) #5
And neither do I…
I’m hoping to replace changing this setting with chat functionality.
But for that I’m looking to post via the API and a SSO proxy server to bypass the minimum character requirements.
(Dylan) #6
I had this issue when some members wanted me to increase the limit, all you have to do is reload the page and it takes affect. You can force a browser refresh on active members or tell them to just reload the page and it’ll work fine.
Not really an issue like @codinghorror said, it doesn’t usually change often.
