Mini_suffix and Freebsd
unsupported-install
(Roman Teuk) #1
Hi! I use Discourse from sources on FreeBSD. Everything was file until I upgraded it to latest version which uses ‘mini_suffix’ gem. Seems that ‘mini_suffux’ includes precompiled libpsl library for Linux and OSX only.
/usr/local/lib/ruby/gems/2.3/gems/ffi-1.9.18/lib/ffi/library.rb:147:in `block in ffi_lib': Could not open library '/usr/local/lib/ruby/gems/2.3/gems/mini_suffix-0.3.0/vendor/libpsl.so': Shared object "libc.so.6" not found, required by "libpsl.so". (LoadError)
Is there any chance to make it working on FreeBSD?
(Rafael dos Santos Silva) #2
Can you compile and supply the dep yourself? Also, you should be using Ruby 2.4 on latest Discourse.
(Roman Teuk) #3
I have installed dns/libpsl port and replaced vendor/libpsl.so inside gem with /usr/local/lib/libpsl.so.
It seems to work now.
Thank you
(Sam Saffron) #4
Our intention is for the gem to always work great BSDs, and PRs to the gem directly to improve its compatibility would be greatly appreciated.
(Matt Palmer) #5
Not vendoring Linux-specific shared libraries would probably be a winning first step…
(Sam Saffron) #6
Yeah the first step here is following a pattern more similar to what libv8 gem does where we push a “general” gem that compiles from source and then a platform specific gems for each platform.
