Minor mobile style bugs
(NomNuggetNom ) #1
###User title is too far down
The main problem here is trying to cram three lines of text in a 45px height, but it seems the user title is abnormally low. Removing the padding-top: 2px from the .user-title mobile CSS helps:
But it still looks a little weird.
###Dropdowns overlay the header
Normally this is no problem:
As you can see, the drop down just barely rests above the banner. It’s a nice look. Problems arise when the dropdown is not fixed to the top, like on the users page:
When you scroll down, the dropdown stays in place, totally overlapping the header.
(Khoa Nguyen) #2
@NomNuggetNom I mentioned the second problem in this topic
https://meta.discourse.org/t/should-the-popup-below-the-navbar/26904?source_topic_id=26947
Simple solution is applied a custom CSS
.d-header {
    z-index: 10000;
(Kane York) #3
Shouldn’t you lower the z-index of the page’s popup, instead of raising the z-index of the header?
(Khoa Nguyen) #4
There is many type of popup like : share popup, topic admin popup, … I think the best way is raising the z-index of header
(Arpit Jalan) #5
Fixed via:
