Missing Russian Poll translation
(Ilya Kuchaev) #1
It’s in Transifex
but
(Gerhard Schlager) #2
Looks like that the script used for pulling translations from Transifex doesn’t download all needed files.
I guess @techAPJ or @neil should take a look at this. Those files are missing for most of the languages.
(Neil Lalonde) #3
I see the problem. @techAPJ can you add missing files like the Russian poll/client.en.yml? The Transifex command line tool won’t pull files that don’t exist, so we need to add them manually the first time. :cry:
(Gerhard Schlager) #4
According to the documentation there’s a parameter which should work:
-a: Fetch all translation files from server (even new ones)
If it doesn’t, then try a little force. :wink:
-f: Force download of translations files
(Arpit Jalan) #5
Should be fixed now.
https://github.com/discourse/discourse/pull/2879
Thanks for reporting!
(probus) #6
Why were fi translations not added?
(Arpit Jalan) #7
Added in this PR:
