Moderator Metrics
Hi,
Is there a way to see a dashboard of our Moderator’s work? Total posts, time to answer, etc?
Thanks!
If you go to there profile go to summary this should help!
Thanks Quinn! Is there a way to see all of them without going to each individual profile?
Um no not at the moment I don’t think!
If this helps you can also hit the
Three lines users change the week to all time and then there’s all the users!
I don’t know if there is a way to see all of the status, but you can see all of any trust level’s posts by tagging:
@trust_level_4
And so on for each trust level.
If you click on the tag, it will take you to what looks like a regular user profile, but for a whole trust level of users.
I’m not sure if this actual tags the individual users, though. Apologies to the Admins if the tag does. :sweat_smile:
Not specifically, I believe, but if it helps, go to the users tab:
Then, click on filter by username:
And search the user in there! It should give you a summary of what they have done on the forum. :smile:
Nope, but what you showed is a simple way to see all the users in a group. However, I wouldn’t recommend it, as it’s a bit more tedious. :slightly_smiling_face:
