Modify Top Menu buttons?
(Sanwu-three) #1
Hey guys,
I want modify the top buttons. “rename” , “delete” or add new button.
So, Where the Setting can modify that ?
Discourse Solved (Accepted answer plugin)
(Alexander Wright) #2
Type “top menu” into the setting search filter.
I’m not sure you can rename buttons, but there’s a limited number you can add.
(Allen - Watchman Monitoring) #3
This is in the Admin view’s Top Menu
/admin/site_settings/category/basic
(Sanwu-three) #4
So
I Added a button named “unsolved” in setting panel.
But , it looks like not apply
(Allen - Watchman Monitoring) #5
Maybe that’s a feature request for the Solved Plugin?
(Sanwu-three) #6
i have installed “Solved Plugin”.
