Ok, even though I don’t own a discourse site yet, I’ve decided to create a “5 step approach to keeping a civilized community”! You can follow these rules and modify them in any sort of way you want (like switching the order)!
- Nudge a user- The first moderation action that should be taken is to nudge a user (sending them a PM reminding them of their behavior). When nudging a user, you should mention that if the user doesn’t change his/her behavior, an official staff warning will be issued!
- Issue an official staff warning- If a user is acting up after initial contact, an official staff warning should be issued! This will show with a red envelope to mark it as an official staff warning! In the official staff warning, you should mention the potential consequences that may occur if a user fails to change his/her behavior.
- Silence or suspend the user- If the user fails to change their behavior after initial contact and an official staff warning, your next bet is to silence or suspend the user! Now, the choice is up to you, however, the main thing you should consider when deciding whether to silence or suspend a user is the severity of the user’s offense or offenses! For example, if a user is doing something mild like using excessive profanities, you should silence a user in that case! However, if it’s a more severe offense you might want to consider suspending the user, rather than just silencing them!
- Suspend the user or lengthen the suspension time- If a user is still acting up (even after initial contact, an official staff warning, and a silence or suspension), you should then suspend the user! If the user has been previously suspended, you can choose if you wish to give them a second chance (however with a longer suspension time) or choose to permanently suspend them from your community! If you choose to suspend the user (either way), you should let them know that this is their last chance and another offense will result in a permanent suspension! Please note that when suspending a user, the length of the suspension should be considered wisely! Please consider the following factors when suspending a user
- If the user has been previously suspended
- The severity of the user’s offense or offenses
- The frequency of the offenses (how often they are being performed)
- Permanently suspend the user- If a user is acting up after the steps above have been followed, you should then just permanently suspend the user (as they clearly have no intention of changing their behavior at this point)!
Note: Some of the formattings from the original document have been removed (to save time)! You can find the document with full formatting at
Note: Permissions to view, print, download, and copy have been disabled!
