My first plugin. Need advice
(Steven Slade) #1
I am creating my first plugin. Here’s the outline on what it should do:
It should allow me to get the custom_groups of a user. The reason there is some handlebars in the plugin is because I eventually want to change the state of nav-bar depending on a user’s custom_groups.
The plugin should access the Users Controller, get their custom groups with:
groups = current_user.groups.all.select("name") and then take the data from that and render it in json for the javascripts/initializer to make an ajax call and get the user’s custom groups.
Here is the plugin: GitHub - stevenpslade/discourse-data-menu-item
As aforementioned, this is my first one and I am having trouble even testing what results I’m getting from the ajax call as well as if the code in the controller is correct. I’m used to being in a pure rails app where I can use byebug’s and binding.pry’s.
If a more experienced plugin dev could give this a once over and maybe give me some advice, I would really appreciate that. I hope to continue making Discourse plugins after I get past this first one! :slightly_smiling:
(Régis Hanol) #2
Here’s my take on it
  • Rather than creating a new controller, I would instead extend the CurrentUserSerializer and add the groups
  • Then I would use one of the extensibility point for the navigation bar template (and controller) to add my own logic depending on the groups returned
(Steven Slade) #3
@zogstrip: In the CurrentUserSerializer, would it need something like:
def group_names
    object.groups.all
I am playing around with it and trying to test in dev tools using Discourse.User.current().group_names but it’s coming up undefined. Obviously object.groups.all won’t do the trick here, what would I need to do to add the groups?
(Sam Saffron) #4
Group names is object.groups.pluck(:name)
(James Kiesel) #5
Chrome (other modern browsers too) have quite fantastic javascript debuggers built into them, which should provide you with all the breakpointy goodness you’d be used to from ruby.
There’s a great codeschool tutorial on it as well:
http://discover-devtools.codeschool.com/
