My PM inbox shows gray 1 after I write message to someone
(Anton) #1
Not sure if it quialifies as a bug, but to me it looks like an undesired and unexpected behavior.
After writing a new message in a PM thread and then switching to my inbox list, a “1” is shown in a gray circle.
(zombieslayer124) #2
Yes I have been getting this issue, to remove it just click on the topic! I guess it’s because you were not at the bottom of the topic while writing a post, then you haven’t read it. But you have already viewed the topic which makes it grey insetead of blue. Idk if this is true, but that’s what I think! :smile:
(Jeff Atwood) #3
Yes, correct, grey means unread but not new (these posts existed in the topic the last time you visited). Blue means unread and new.
(Anton) #4
So needs to be fixed?
First, there is no counter in front of the topic, then it appears after I post a message - not what one would expect.
(Sam Saffron) #5
Yes its a minor bug.
We should treat your posts as “unconditionally” read and not rely on read time tracker to mark it read.
(Jeff Atwood) #6
Not a bug until we have repro steps, and I cannot repro this.
(Sam Saffron) #7
I am pretty sure it requires a very very bad internet connection, or impeccable timing.
(zombieslayer124) #8
I have tested something on our forum, if you open a reply and scroll up in the topic while still being in this “reply” mode, and then reply, it will do this.
