My Steam won't connect
Whenever I click “connect to steam” a window tries to load, and then I get an error message that says “You’ve been logged out. Please sign in again.” I’m not sure what to do. I’m fully logged into my steam account so I’m super confused.
Is this on a site you administer?
If so can you run us through the troubleshooting steps you’ve taken so far?
I get that error on all oAuth plugins sometimes. Refresh if it’s an issue, and also check your /logs if thaat didn’t fix it and tell me what you see. It should be like discourse-steam-login: Failed authentication or something similar
