Namecheap's private email not working
I’m using Namecheap’s private email service (with default DNS), but it doesn’t seem to be working. Any suggestions? Here are my settings:
DISCOURSE_SMTP_ADDRESS: mail.privateemail.com
DISCOURSE_SMTP_USER_NAME: admin@[domain I registered].com
DISCOURSE_SMTP_PORT: 465
DISCOURSE_SMTP_PASSWORD: [password I use to log into email]
DISCOURSE_SMTP_ENABLE_START_TLS: false
I’ve also referred to this similar post (turn on TLS, set port to 26) with no luck.
In the production logs I’ve got this multiple times:
Sent mail to admin@[domain I registered].com (10381.3ms)
Job exception: Connection reset by peer
Hello , It is work or not ?
It works fine
But i stopped the project
Did you test is for big communiity or not really ? How many mails arrived to spam folder ?
Hi @Biarity check this out Solution for privateemail configurations
no it was just a test. non of them arrived to the spam folder
Thank for info. Did you know it is possible to use 2 emails accounts or more (for example for namecheap) to use for one installation of discourse . I asking becouse email hosting have a limit to 200 mails per hour.
