Need help for migrate from one discourse to another
(Vincent Lee) #1
hello everyone, i am a new guy with discouse.
i have some post in discourse forum A, but now i decide not to use forum A anymore (use forum B which is also based on discoucse in the fulture), so i download all my post(a file names like user-archive-lian-160723-073508-13.csv.gz) to local.
and the problem i encounter is: how could i import my old data to forum B.
i have search for a while and i know there is script at discourse/script/import_scripts at master · discourse/discourse · GitHub, but i know little about coding, so is there some easy way to migrate?
(Vinoth Kannan) #2
If your forum B is fresh install you shouldn’t worry about anything. In admin side just take backup from forum A and import in forum B. You can do all these in admin side itself. No need for any coding skills
