Need help on listing subcategories by alphabetical order
(Darrel Drobnich) #1
Can someone let me know if this is possible and how to do it.
Thanks.
(Michael Downey) #2
I think the only option is to do it manually, by using the position setting in the “Settings” tab under each category’s “Edit” dialog box. Enter the number for the sequence you’d like that category to appear in. Once you’ve completed all the categories, they should look like you want!
(Darrel Drobnich) #3
Thanks.
I’ll give it a try.
(Jeff Atwood) #4
Numbers are no longer required. There is a UI for this, see the 1.4 release blog post for a video animation of how it works.
