Needs help regarding badges for discourse-solve code
I edited the discourse-solved plugin code to hide the correct checkbox if you are not the OP but it kinda broke my badges. It doesn’t work anymore. Can somebody help me see what part of the code I should update on my badges in order for it to work again? Thank you.
Edited code on the discourse-solved plugin:
api.addPostMenuButton('solved', attrs => {
    const canAccept = attrs.can_accept_answer;
    const canUnaccept = attrs.can_unaccept_answer;
    const accepted = attrs.accepted_answer;
    const isOp = currentUser && currentUser.id === attrs.topicCreatedById;
    const position = (!accepted && canAccept && !isOp) ? 'second-last-hidden' : 'first';
    if (canAccept) {
      return {
        action: 'acceptAnswer',
        icon: 'check-square-o',
        className: 'unaccepted',
        title: 'solved.accept_answer',
        position
    } else if (canUnaccept) {
      const title = canUnaccept ? 'solved.unaccept_answer' : '';
      return {
        action: 'unacceptAnswer',
        icon: 'check-square',
        title,
        className: 'accepted fade-out',
        position,
        beforeButton(h) {
          return h('span.accepted-text', I18n.t('solved.solution'));
    } else if (accepted) {
      const title = accepted ? 'solved.accepted_answer' : '';
      return {
        icon: '',
        title,
        className: 'not-op-accepted fade-out',
        position,
        beforeButton(h) {
For Badge: This code is the example from discourse forum:
SELECT p.user_id, p.id post_id, p.updated_at granted_at
FROM badge_posts p
WHERE p.post_number > 1 AND
    p.id IN (
      SELECT post_id FROM (
       SELECT pc.post_id, row_number()
       OVER (PARTITION BY p1.user_id ORDER BY pc.created_at) as rnum
       FROM post_custom_fields pc
       JOIN badge_posts p1 ON p1.id = pc.post_id
       JOIN topics t1 ON p1.topic_id = t1.id
       WHERE name = 'is_accepted_answer' AND
                     value IS NOT NULL AND
                    p1.user_id <> t1.user_id AND
          :backfill OR
           p1.user_id IN (
                   select user_id from posts where p1.id IN (:post_ids)
) X  WHERE rnum = 1)
Isn’t this how the plugin already works?
@Falco I doesn’t work that way.
The plug-in shows the word “SOLUTION” with the green checkbox to both the OP and readers. I requested if the checkbox can be hidden to readers since they don’t have the ability to uncheck it. This suggestion is for UX purposes.
However, I was able to make the changes but my badges are not working properly anymore. I don’t know if my changes affected the badges and is looking for advice from the discourse-solved team. Thank you.
See discussion here:
