NoMethodError (launcher rebuild app)
(Evgeny) #1
[2017-09-25T19:22:59.759723 #14]
INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate'
rake aborted!
Summary
/var/www/discourse/plugins/discourse-voting/app/controllers/discourse_voting/votes_controller.rb:3:in `<class:VotesController>'
/var/www/discourse/plugins/discourse-voting/app/controllers/discourse_voting/votes_controller.rb:2:in `<module:DiscourseVoting>'
/var/www/discourse/plugins/discourse-voting/app/controllers/discourse_voting/votes_controller.rb:1:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-5.1.3/lib/active_support/dependencies.rb:292:in `require'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-5.1.3/lib/active_support/dependencies.rb:292:in `block in require'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-5.1.3/lib/active_support/dependencies.rb:258:in `load_dependency'
/var/www/discourse/plugins/discourse-voting/plugin.rb:268:in `block in activate!'
/var/www/discourse/lib/plugin/instance.rb:248:in `block in notify_after_initialize'
/var/www/discourse/lib/plugin/instance.rb:246:in `each'
/var/www/discourse/lib/plugin/instance.rb:246:in `notify_after_initialize'
/var/www/discourse/config/application.rb:211:in `each'
/var/www/discourse/config/application.rb:211:in `block in <class:Application>'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-5.1.3/lib/active_support/lazy_load_hooks.rb:43:in `execute_hook'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-5.1.3/lib/active_support/lazy_load_hooks.rb:52:in `block in run_load_hooks'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-5.1.3/lib/active_support/lazy_load_hooks.rb:51:in `each'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-5.1.3/lib/active_support/lazy_load_hooks.rb:51:in `run_load_hooks'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/railties-5.1.3/lib/rails/application/finisher.rb:73:in `block in <module:Finisher>'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/railties-5.1.3/lib/rails/initializable.rb:30:in `instance_exec'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/railties-5.1.3/lib/rails/initializable.rb:30:in `run'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/railties-5.1.3/lib/rails/initializable.rb:59:in `block in run_initializers'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/railties-5.1.3/lib/rails/initializable.rb:58:in `run_initializers'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/railties-5.1.3/lib/rails/application.rb:353:in `initialize!'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/railties-5.1.3/lib/rails/railtie.rb:185:in `public_send'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/railties-5.1.3/lib/rails/railtie.rb:185:in `method_missing'
/var/www/discourse/config/environment.rb:5:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/railties-5.1.3/lib/rails/application.rb:329:in `require_environment!'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/railties-5.1.3/lib/rails/application.rb:445:in `block in run_tasks_blocks'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rake-12.0.0/exe/rake:27:in `<top (required)>'
/usr/local/bin/bundle:22:in `load'
/usr/local/bin/bundle:22:in `<main>'
Tasks: TOP => db:migrate => environment
I, [2017-09-25T19:23:10.352672 #14]  INFO -- :
I, [2017-09-25T19:23:10.353695 #14]  INFO -- : Terminating async processes
I, [2017-09-25T19:23:10.353865 #14]  INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/9.5/bin/postmaster -D /etc/postgresql/9.5/main pid: 44
2017-09-25 19:23:10.354 UTC [44] LOG:  received fast shutdown request
2017-09-25 19:23:10.354 UTC [44] LOG:  aborting any active transactions
2017-09-25 19:23:10.354 UTC [51] LOG:  autovacuum launcher shutting down
I, [2017-09-25T19:23:10.354255 #14]  INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 157
157:signal-handler (1506367390) Received SIGTERM scheduling shutdown...
2017-09-25 19:23:10.358 UTC [48] LOG:  shutting down
157:M 25 Sep 19:23:10.371 # User requested shutdown...
157:M 25 Sep 19:23:10.371 * Saving the final RDB snapshot before exiting.
2017-09-25 19:23:10.376 UTC [48] LOG:  database system is shut down
157:M 25 Sep 19:23:10.572 * DB saved on disk
157:M 25 Sep 19:23:10.572 # Redis is now ready to exit, bye bye...
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate' failed with return #<Process::Status: pid 10774 exit 1>
Location of failure: /pups/lib/pups/exec_command.rb:108:in `spawn'
exec failed with the params {"cd"=>"$home", "hook"=>"bundle_exec", "cmd"=>["su discourse -c 'bundle install --deployment --verbose --without test --without development'", "su discourse -c 'bundle exec rake db:migrate'", "su discourse -c 'bundle exec rake assets:precompile'"]}
4ab8ca560a347103e631a7f30084ed2495b005d825145a61b9fbbe72e8c17453
** FAILED TO BOOTSTRAP ** please scroll up and look for earlier error messages, there may be more than one
(Alan Tan) #2
Which branch of Discourse are you on?
(Evgeny) #3
v1.9.0.beta10 +59 1.9.0.beta10
(Alan Tan) #4
Can I get the full error message? The stacktrace is there but not the message.
(Evgeny) #5
Unfortunately I don’t have the full error log (deleted). When, in the future, will include this plug-in and something goes wrong, I will post a full error log. Thank you.
(Alan Tan) #6
Does that mean you’re able to rebuild now? :slight_smile:
(Evgeny) #7
Yesterday I removed the plugin (app.xml), because with it the reconstruction was impossible. Without the plugin, all is well.
