Non-LetsEncrypt SSL certificate
(Susan Spencer) #1
FYI, if you use non-Let’s Encrypt certificates, here are steps to install your SSL certificate files. My certs come from DigiCert, so I’ll use it in the example:
After you’ve received your-domain_com.crt (primary certificate), DigiCert.crt (intermediate certificate) and your-domain_com.key:
  1. Check them for errors: (more about this here)
openssl x509 -in your-domain_com.crt -text -noout
openssl x509 -in DigiCert.crt -text -noout
openssl rsa -in ssl.key -text -noout
  1. Upload them to this directory (create the directory if needed)
/var/discourse/shared/standalone/ssl
  1. Concatenate the .crt files, with your domain crt file as the first file, to ssl.crt
cat your-domain_com.crt DigiCert.crt > ssl.crt
  1. Copy your key file to ssl.key
cp your-domain_com.key ssl.key
  1. Update the /var/discourse/containers/app.yml file:
    web.template.yml and web.ssl.template.yml – uncomment in templates section
    “85:80”, “2222:22”, and “443:443” – list these on separate lines in exposed section
  2. Set permissions on the ssl directory & files to the same user & group as your
    /var/discourse/shared/standalone/uploads directory
    (this allows nginx to find the ssl files) - the directory should not belong to root.
chown -R youruser:yourgroup /var/discourse/shared/standalone/ssl
  1. Rebuild app from /var/discourse directory:
./laucher rebuild app
  1. Check logs for errors:
./launcher logs app
