Not able to restore the backup
I have the backup of my old discourse forum that I deleted some months ago, but I kept its backup.
Yesterday, I installed a new discourse forum and tried to restore the same backup of my old discourse forum. But it got failed, I tried many times but same error.
Here is what logs says:
EXCEPTION: lib/discourse.rb:92:in `exec’: Failed to decompress archive.
it seems that your backup is corrupt
But I had downloaded the backup using the official way through my discourse forum
You can try to uncompress it yourself.
Then, how can I upload that in discourse? Can you explain it a bit more.
When you try to uncompress it, does it work? I’m guessing no. If you can uncompress it, then I don’t have an idea. There are many ways that a fire can get corrupted. The best bet is that yours is.
I can easily compress it on my computer but when uploading, it got failed. Same error every time.
What is the filename of your backup (including extension) ?
If you decompress the backup on your computer, what files do you see?
