Not all thin sockets being created
(Brendan) #1
I was looking at my nginx logs, and it was complaining about thin.2.sock and thin.3.sock not being available. I checked and they’re not in discourse/tmp/sockets/ … only thin.0.sock and thin.1.sock were created.
Yet, in the nginx config file, upstream defines 4 sockets (0-3). Is there somewhere else that I need to tell discourse to create the other sockets?
(Brendan) #2
Er, ok, solved my problem. When starting bluepill, NUM_WEBS was =2, which caused the problem.
NUM_WEBS=4 created all 4 sockets.
(Sam Saffron) #3
super duper extra strongly recommend moving to a docker based install, our only supported install.
We no longer use thin or bluepill
(Jeff Atwood) #4
