Nothing happens when i try to publish a topic
when i try to create topic nothing happens like it freezes and nothing happens.
How did you create this topic if you can’t create a topic?
I mean when i write my content ( in my forum ) and want to publish it by clicking “ create topic “ , nothing happens.
Are you admin and able to check settings? If not then it is difficult to tell.
  • Maybe read only mode is enabled. Or it is enabled for backups only: Enable read only mode while taking a backup?
  • Is Minimum number of tags required in a topic set for the category and you haven’t added enough tags?
  • Is a plug-in causing this problem? It has happened before e.g. Cannot create new topics (already disabled plugins)
Can you add posts in an existing topic or edit a topic and save the changes? If you are admin can you edit a category description topic?
I wonder if this could happen if Digital Ocean, or whoever your hosting service is, having problems with your droplet/VPS and they’ve prevented writes to the database?
Are there any JavaScript errors in your browser’s console when you hit the Create Topic button?
None, there is no error
Is your Discourse up to date? Have you tried safe mode?
