OAuth2 login error
I return json data
    "id": 51.0,
    "avatar": "https://xxxxx.png",
    "email": "xxxxx@qq.com"
Iā€™m not a 100% sure since there are no logs but my most informed guess here is that
Contains a . which could be causing the problem.
I also notice that you have a typo in the oauth2_json_email_verified_path. I guess email_vefify should be email_verify.
As @itsbhanusharma said, the error logs would be helpful to diagnose the problem. Can you try visiting /logs on your forum when logged in an as admin, and share the relevant error. Make sure to scrub any sensitive information.
