Onebox embedded content not appearing in discussions embedded in blog
(Tobias Eigen) #1
This blog post has comments powered by a discourse topic. In my reply to the topic, I included a link to a youtube video. It is not appearing below the blog post in the comments, while it does show up in the accompanying discourse topic. I think this is a bug because I expect it to appear in both places. If onebox is not supported, at least it should display the URL to the embedded content.
Screenshot of comment in blog:
Screenshot of comment in discourse:
(Arpit Jalan) #2
This is a legit bug, I am on it.
(Arpit Jalan) #3
Okay, I just pushed a fix for this:
https://github.com/discourse/wp-discourse/commit/7e288c481dd0342a2d9ee28037e78198f26d9c27
Can you update the plugin and try again? Thanks for reporting it!
(Tobias Eigen) #4
I just updated to master and the bug is still showing on my site.
Are we using the same plugin? I used @eviltrout’s recipe for static sites for my drupal site, not a wordpress plugin. Do I need to update the embed code I used on my blog?
(Arpit Jalan) #5
Nope, I fixed the wordpress plugin.
Yes, in that case you will need to update the embed code. The fix is relatively easy though, you will need to inject custom javascript, have a look at the wordpress fix:
https://github.com/discourse/wp-discourse/blob/master/js/discourse.js
The above javascript code is all that is required to fix the youtube embedding issue.
(Arpit Jalan) #6
Fixed via
https://github.com/discourse/discourse/pull/3419
Now embedded comments will include YouTube video link.
(Arpit Jalan) #7
