Optional Link to Main Site?
(Ker Ruben Ramos) #1
Should there be an optional settings to show link to a Main Website?
For example, a button besides the profile on top-right which links to a Parent Website will show if some configuration setting is not empty.
Also, a plus would be having an optional icon setting for button. If not, uses a default icon.
I’m pretty sure I’ve seen some Discourse host that already had this feature. I just forgot the address though.
(Alejandro Petroff) #2
Yes, we’re facing the same problem. Forum is just forum for the main site and users ask us for a comfortable navigation between forum and main site.
(Sam Saffron) #3
Where would you have this link, care to create a visual mock.
Keep in mind you can do something like http://discuss.howtogeek.com/ with the current system.
(Alejandro Petroff) #4
mmmm… looks nice, it seems to solve the problem.
(Ker Ruben Ramos) #5
As one of the buttons. I’ve seen someone hosting a Discourse with such feature.
Regarding how-to-geek, too much size occupied.
(Sam Saffron) #6
I want to add support for “custom” menu items (like latest/new/unread) into core, as of now there is no such feature.
(Ker Ruben Ramos) #7
No hurry. I just shared it cause I see users complaining about not easily navigating through main.
Thanks
(Alejandro Petroff) #8
The idea is great also.
(Salman, Freelance Developer) #9
Was just going to create a new feature topic on this.
I really hate it when people don’t have a link back to the main site, be it from a forum or a blog.
I think having this in the settings would be a good idea, and the link should be somewhere on the top header I would say.
(happycollision) #10
Is there any documentation anywhere about how Boing Boing and How to Geek added the header links back to their sites? I’d like to do it in a way that doesn’t screw up pulling changes from the repo.
(Michael John Kirk) #11
You can add arbitrary html/css to the top of every page using the customization feature in admin.
Just go to https://forums.yoursite.com/admin/customize
(Tobias Eigen) #12
Here’s a visual mock for how this might look. The house would link to the main site, and would appear if a URL is provided via an admin setting.
Thanks @AdamCapriola for suggesting.
(Adam Capriola) #13
I think some kind of home icon would be great as a configurable option. I’ve been pondering for a while how to best link back to my home page!
I don’t like giving up vertical real estate to add one key link. If you have a whole set of navigation links you want displayed, then yeah – add a menu on top – but otherwise I think it makes sense to have a simple home icon. Easy for anyone to turn on and off.
(I’m also awaiting the debut of the new side menu. Maybe that will be a good place for a home link.)
(Dean Taylor) #14
Personally I have added a combination of a “Home” link and deeper links into the main site to the Hamburger Menu, making them accessible to mobile users:
https://meta.discourse.org/t/adding-a-menu-item-to-the-hamburger-menu/24466?u=deanmarktaylor&source_topic_id=7537
It depends on your site as to how important getting back to the main site is.
(Jeff Atwood) #15
Yes as mentioned earlier this a customization Bitnami made on their instance as well:
(Blu McCormick) #16
Hello, does anyone know what the latest is for the best way to have a way to navigate from the forum back to the mother website? A button or the website menu at the top . . . something like that? Thanks.
(Joshua Rosenfeld) #17
There are multiple methods. You can add a custom header like these docs:
You could also add a link besides the search icon:
(Blu McCormick) #18
Thank you so much. That was most helpful. You made my day!
(Joshua Rosenfeld) #19
This topic was automatically closed after 2 days. New replies are no longer allowed.
