OVH + cloudflare + mailgun
(DjCyry) #1
Hi ,
I want to test ovh ssd or cloud vps servers.
I am thinking about ssd2 or cloud2 package .
So , as i know , the panel of ovh and dns setting are a little hard to understand , so my question is :
Can i use/create cloudflare dns with the vps ip ?
Can i use also mailgun with cloudflare ?
Any recomendation / review ?!
Actually , DO client .
Thanks in advance .
(Martial) #2
Hi
I use :
  • OVH VPS SSD with 20Go
  • sendgrid
  • cloudflare
Everything work as expected :slight_smile:
(DjCyry) #3
Hello and thanks .
So you have put the vps ip on cloudflare and create dns servers , then you have add the mails settings to dns of cloudflare and finally change your dns on your domain registrer ?
(Martial) #4
Yep
Yep on cloudflare
yep again
I only use the OVH dns panel to set the DNS of cloudfare
(DjCyry) #5
And you have the domain with ovh ? In my case , no .
(Martial) #6
Yes with OVH, but it doesn’t matter. You just have to put the dns of cloudlfare in the dns panel where you buy your domain
(DjCyry) #7
Yes , more simple than ovh setting :sweat_smile:.
I will try this days , thanks .
Any downtime or problems with them ?
(Martial) #8
No downtime if you pay on time :wink:
(DjCyry) #9
Do you also have this ?
2017-09-28 13_39_48-Your OVH Dedicated Customer Zone
i have make a fresh install and i get : ERR_CONNECTION_TIMED_OUT on ip and domain name .
(Martial) #10
Never trust the OVH panel :wink:
(DjCyry) #11
Yeah …its a crap .
Seems to works fine now . Thanks
