Persona Login Plugin
(Raphaël Jadot) #21
Generally Mozilla uses something close to this one
http://fortawesome.github.io/Font-Awesome/icon/user/
Loomio uses one close to this one
http://fortawesome.github.io/Font-Awesome/icon/envelope/
I’d gladly made a pull request but don’t know yet how to find the related character…
In fact, better use no glyphs at all than “]” and remove
.btn-social.persona:before {
  content: "]";
(Leo McArdle) #22
For use on https://discourse.webmaker.org/ I CSSed in an image on discourse-persona-mozillians to produce:
I was initially reluctant to push this upstream (and then forgot) because I’m not sure how kosher it is, particularly because we’re serving the image off our own CDN: (there is a slight delay after the popup opens before the icon appears)
I’m gonna experiment with embedding the image inline as an svg in the css, and if that works, submit a pull request upstream. :smile:
(Leo McArdle) #23
Using an inline svg background seems to have worked perfectly. @radq have you had an opportunity to look at my PR?
(Nukeador) #24
Hi,
With the update to 1.5.0.beta7 the plugin stopped showing the login button but the plugin seems to be enabled on the admin panel
(Mittineague) #25
My guess is the plugin code needs to be changed because of Deprecating ES6 compatibility layer
I don’t know if @radq is still around to look into the problem.
(cpradio) #26
I submitted a PR to fix it.
If you need it immediately, you can update your app.yml to point to https://github.com/cpradio/discourse-persona.git
(Nukeador) #27
I see the PR was merged, updated and working, thanks!
(Mike Linksvayer) #28
Shutting down persona.org in November 2016
https://mail.mozilla.org/pipermail/persona-notices/2016/000005.html
https://.ycombinator.com/item?id=10884893
Is there anything Discourse instances using this plugin need to do before then to ensure a smooth transition for users to user/password or other social login? If a user has only ever logged in via Persona, is that a special case at all?
(Sam Saffron) #29
We always expect a working email address, you can always “forget your password” and reset it.
