Pin Globally not working
(Adam Adam) #1
When I try and pin topics globally, they get marked as Pinned globally. But they dont actually get pinned globally?
After pinning globally I noticed that at the bottom it still said “unpinned” and so I again changed that to “Pin globally” but when I refresh the page it goes back to “unpinned”.
(Paula Kreuzer) #2
The “unpinned” on the bottom of the page just means it is unpinned for you. I assume you have the setting enabled to automatically unpin topics (for you) if you reach the bottom of the topic.
It’s in user settings > interface.
(Adam Adam) #3
I cant seem to find that setting
Also, the problem is not only for me. When I view the forum from a different device (that is signed out), I am still unable to view the globally pinned topic
(Kane York) #4
It’s at /my/preferences/interface.
(Adam Adam) #5
Doing this still didnt solve the problem
(Paula Kreuzer) #6
All pinning globally does is make sure the topic is on the top of the /latest view when you load it (until the user unpins it). Maybe what you are looking for is a banner instead?
Or show us a screenshot (or a link) to your /latest view, so we can verify it’s really not working as intended.
(Adam Adam) #7
http://tpvl.trydiscourse.com/
No its not working.
Under newbies corner there is a topic called “getting started” that is the one that needs to be pinned globally. I have already chosen a banner topic, and that is working fine.
(Paula Kreuzer) #8
I believe the issue is that you used the “about this category” post which is not displayed in the /latest view at all (it’s empty), so it can’t really be pinned there either.
Try with a new topic.
(Adam Adam) #9
Thats it.
Problem solved. Thanks!
(Régis Hanol) closed #10
