@ Pinging in parentheses doesn't auto-suggest
(Clay Heaton) #1
I frequently find that I want to @ ping somebody following a particular comment, and that I want to do it in parenthesis. Example:
  • Get a list of the prices (@clay)
The annoyance is that the @ helper list does not pop up when the @ follows an opening parenthesis (@clay ...) or other punctuation, such as a -.
While the ping works when the name is typed in, it’s useful to have the helper popup list because I can see their full name and make sure I pick the right person.
I suspect it works this way so that people can enter email addresses without the helper list popping up?
Anyhow, if you have a list somewhere of minor annoyances, I think this belongs on it.
Mentions don't auto-complete after `(`
(Mittineague) #2
A simple insertion of a space does the trick.
(Clay Heaton) #3
Yes, I’m aware of that. It’s the reason I file this under minor annoyances.
(Alan Tan) #4
I made a fix so this works now.
(Sam Saffron) #5
(@tgxworld) yay :palm_tree:
(Sam Saffron) #6
