Plans to extract jobs Scheduler into a gem?
(Ross Kaffenberger) #1
I came across Discourse’s homegrown Scheduler API after researching options for scheduling recurring jobs in Sidekiq. It looked the popular sidetiq gem has had some performance issues and isn’t actively being updated. Discourse’s Scheduler namespace appears to be well-isolated from the app’s business logic to make it suitable as a standalone gem. Thoughts?
(Régis Hanol) #2
Sure if you want to give it a shot at extracting it.
(Sam Saffron) #3
Sure, I support extracting, you can use the MIT license for your extraction.
