Poll Builder option missing
I seem to have all the default poll settings and polls work when setup manually but the Poll Builder is missing in the composer:
This is on version 2.5.0 but it was missing on a prior version as well. Default discourse-docker install using the web-only template.
Just so that I’m not missing something, did you refresh after enabling that setting?
I can’t reproduce the issue so I moved it to #support
Yes I did a hard-reload in Chrome, and the account is TL4.
Have you already created a poll on that post? There can only be one poll per post I believe.
No the option was missing even before I pasted the poll manually.
The manually-created poll did work after posting:
Our forum is also missing the poll button and also works manually. It disappeared after we did a restore of our forum while moving to the official Discourse installation. We are also missing the button that lets you insert date and time.
Updated to v2.6.0 and the ‘Build Poll’ option is there and working again.
Yep, resolved for us as well! Cheers.
