Polls are frozen due to checklist plugin
#1
The polls are displayed as usual but cannot be clicked on - no votes are calculated and trying to close the poll does nothing. Started doing this about a week ago after upgrading to fix the poll miscalculation ( Broken poll in two places )
(Régis Hanol) #2
Are there any JavaScript errors in your browser’s console?
#3
Yes, I see:
15:50:55.107 TypeError: Discourse.PostView is undefined
<anonymous> application-07db22c6525bc6d375182f19d7f2c8ce.js:58
1 application-07db22c6525bc6d375182f19d7f2c8ce.js:58:18437
15:50:55.865 syntax error1 report_js_error:1:1
Details: PasteAll.org
(Jeff Atwood) #4
Do you have any plugins installed that we don’t ship? That’s usually the problem, so I suggest disabling any third party plugins.
#5
Still frozen. I removed extra repositories in my app.yml and rebuilt. Installed plugins shows:
discourse-details 0.3
checklist 0.1
docker_manager 0.1
lazyYT 1.0.1
poll 0.9
I didn’t have an entry for checklist plugin in app.yml… How else do I disable a plugin?
(cpradio) #6
Which checklist plugin are you using?
(cpradio) #7
Actually, I already know the answer as mine is version 0.1.2. Your checklist plugin is broken, you need to remove it and replace it with
Posting a poll via the API is not working
(Sam Saffron) #8
well then … do a rebuild…
cd /var/discourse
git pull
./launcher rebuild app
#9
Yup. Updating to the newer checklist plugin did the trick. Thanks guys!
(Régis Hanol) #10
