Polls don't work if you forget to add "Poll:" when first creating the topic and add it in later
(Tobias Eigen) #1
Repro steps:
  1. Create a new topic that works with “Poll: title for poll” in the subject and a list of poll options. It will work properly.
  2. Create new topic for the poll and leave out “Poll:” and create the list of poll options as usual. It will, as expected, not work properly as a poll but just display a list.
  3. Go back and edit the poll topic title to add “Poll:” at the beginning. It will, unexpectedly, not work as a poll and just display a list.
(James Finstrom) #2
Is this something that is (relatively) easy to correct? Just ran in to this today… /sadpanda
(Tobias Eigen) #3
I haven’t tested this for a while… but if it’s not working yet then the only solution is to delete the post and start over.
(Caue Rego) #4
Yep, still not working.
Still no big deal.
(Sam Saffron) #5
@radq was this by design, is there a reason this is happening, having a hell of a time debugging this on dev.
(Vikhyat Korrapati) #6
Don’t think it was by design, that doesn’t make much sense. Will look into it today if possible, otherwise during the weekend.
(Sam Saffron) #7
No probs, awesome ! :blush:
(Sam Saffron) #8
One concern is that TL3 can retitle stuff, I am not sure if we want to allow them to convert stuff to polls and out of polls.
(cpradio) #9
They can do the latter regardless… (unless you plan to prevent them from altering titles that start with Poll:, which will likely bring up more questions than not)
(Sam Saffron) #10
Have you had a chance to have a look at this?
(PJH) #11
Or any number of other words:
[pjh@sofa discourse]$ grep closed_prefix . -rB1 | grep -v "\-\-"
./plugins/poll/config/locales/server.zh_CN.yml-    prefix: "投票"
./plugins/poll/config/locales/server.zh_CN.yml:    closed_prefix: "已关闭的投票:"
./plugins/poll/config/locales/server.de.yml-    prefix: "Umfrage"
./plugins/poll/config/locales/server.de.yml:    closed_prefix: "Beendete Umfrage"
./plugins/poll/config/locales/server.ru.yml-    prefix: "Опрос"
./plugins/poll/config/locales/server.ru.yml:    closed_prefix: "Завершившийся опрос"
./plugins/poll/config/locales/server.pt.yml-    prefix: "Votação"
./plugins/poll/config/locales/server.pt.yml:    closed_prefix: "Votação encerrada"
./plugins/poll/config/locales/server.ca.yml-    prefix: "Enquesta"
./plugins/poll/config/locales/server.ca.yml:    closed_prefix: "Enquesta tancada"
./plugins/poll/config/locales/server.en.yml-    prefix: "Poll"
./plugins/poll/config/locales/server.en.yml:    closed_prefix: "Closed Poll"
./plugins/poll/config/locales/server.pl_PL.yml-    prefix: "Ankieta"
./plugins/poll/config/locales/server.pl_PL.yml:    closed_prefix: "Zamknięta ankieta"
./plugins/poll/config/locales/server.it.yml-    prefix: "Sondaggio"
./plugins/poll/config/locales/server.it.yml:    closed_prefix: "Sondaggio Chiuso"
./plugins/poll/config/locales/server.he.yml-    prefix: "הצבעה"
./plugins/poll/config/locales/server.he.yml:    closed_prefix: "הצבעה סגורה"
./plugins/poll/config/locales/server.ko.yml-    prefix: "투표"
./plugins/poll/config/locales/server.ko.yml:    closed_prefix: "투표 닫기"
./plugins/poll/config/locales/server.ar.yml-    prefix: "تصويت"
./plugins/poll/config/locales/server.ar.yml:    closed_prefix: "هذا التصويت مغلق"
./plugins/poll/config/locales/server.es.yml-    prefix: "Encuesta"
./plugins/poll/config/locales/server.es.yml:    closed_prefix: "Encuesta cerrada"
./plugins/poll/config/locales/server.tr_TR.yml-    prefix: "Anket"
./plugins/poll/config/locales/server.tr_TR.yml:    closed_prefix: "Bitmiş Anket"
./plugins/poll/config/locales/server.fr.yml-    prefix: "Sondage "
./plugins/poll/config/locales/server.fr.yml:    closed_prefix: "Sondage fermé "
./plugins/poll/config/locales/server.fi.yml-    prefix: "Kysely"
./plugins/poll/config/locales/server.fi.yml:    closed_prefix: "Suljettu kysely"
./plugins/poll/config/locales/server.pt_BR.yml-    prefix: "Votação"
./plugins/poll/config/locales/server.pt_BR.yml:    closed_prefix: "Votação encerrada"
Note the related bug however:
(Gareth Coles) #12
Having the same issue as OP, this additionally will happen if you have a post that wasn’t designed with a poll in mind (no list or "Poll: " in the thread name). I attempted to edit a post to add a poll to it, first changing the name and then adding the list. The following happened…
  • The name change worked nicely.
  • The edit is rejected - if I reload the page, the edit hasn’t gone through and is saved as a draft, waiting to be submitted.
I also noticed the following in my error logs…
NoMethodError (undefined method `keys' for nil:NilClass)
/var/www/discourse/plugins/poll/poll.rb:40:in `ensure_can_be_edited!'
/var/www/discourse/plugins/poll/plugin.rb:123:in `poll_options'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.1.8/lib/active_support/callbacks.rb:424:in `block in make_lambda'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.1.8/lib/active_support/callbacks.rb:184:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.1.8/lib/active_support/callbacks.rb:184:in `block in simple'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.1.8/lib/active_support/callbacks.rb:185:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.1.8/lib/active_support/callbacks.rb:185:in `block in simple'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.1.8/lib/active_support/callbacks.rb:86:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.1.8/lib/active_support/callbacks.rb:86:in `run_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activemodel-4.1.8/lib/active_model/validations.rb:376:in `run_validations!'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activemodel-4.1.8/lib/active_model/validations/callbacks.rb:111:in `block in run_validations!'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.1.8/lib/active_support/callbacks.rb:82:in `run_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activemodel-4.1.8/lib/active_model/validations/callbacks.rb:111:in `run_validations!'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activemodel-4.1.8/lib/active_model/validations.rb:317:in `valid?'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.8/lib/active_record/validations.rb:70:in `valid?'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.8/lib/active_record/validations.rb:77:in `perform_validations'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.8/lib/active_record/validations.rb:51:in `save'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.8/lib/active_record/attribute_methods/dirty.rb:21:in `save'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.8/lib/active_record/transactions.rb:268:in `block (2 levels) in save'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.8/lib/active_record/transactions.rb:329:in `block in with_transaction_returning_status'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.8/lib/active_record/connection_adapters/abstract/database_statements.rb:199:in `transaction'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.8/lib/active_record/transactions.rb:208:in `transaction'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.8/lib/active_record/transactions.rb:326:in `with_transaction_returning_status'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.8/lib/active_record/transactions.rb:268:in `block in save'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.8/lib/active_record/transactions.rb:283:in `rollback_active_record_state!'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.8/lib/active_record/transactions.rb:267:in `save'
/var/www/discourse/lib/post_revisor.rb:215:in `update_post'
/var/www/discourse/lib/post_revisor.rb:197:in `revise'
/var/www/discourse/lib/post_revisor.rb:162:in `revise_post'
/var/www/discourse/lib/post_revisor.rb:115:in `block in revise!'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.8/lib/active_record/connection_adapters/abstract/database_statements.rb:201:in `block in transaction'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.8/lib/active_record/connection_adapters/abstract/database_statements.rb:209:in `within_new_transaction'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.8/lib/active_record/connection_adapters/abstract/database_statements.rb:201:in `transaction'
/var/www/discourse/lib/post_revisor.rb:114:in `revise!'
/var/www/discourse/app/controllers/posts_controller.rb:151:in `update'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.8/lib/action_controller/metal/implicit_render.rb:4:in `send_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.8/lib/abstract_controller/base.rb:189:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.8/lib/action_controller/metal/rendering.rb:10:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.8/lib/abstract_controller/callbacks.rb:20:in `block in process_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.1.8/lib/active_support/callbacks.rb:113:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.1.8/lib/active_support/callbacks.rb:149:in `block in halting_and_conditional'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.1.8/lib/active_support/callbacks.rb:166:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.1.8/lib/active_support/callbacks.rb:166:in `block in halting'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.1.8/lib/active_support/callbacks.rb:149:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.1.8/lib/active_support/callbacks.rb:229:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.1.8/lib/active_support/callbacks.rb:229:in `block in halting'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.8/lib/abstract_controller/callbacks.rb:19:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.8/lib/action_controller/metal/rescue.rb:29:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.8/lib/action_controller/metal/instrumentation.rb:31:in `block in process_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.1.8/lib/active_support/notifications.rb:159:in `block in instrument'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.1.8/lib/active_support/notifications/instrumenter.rb:20:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.1.8/lib/active_support/notifications.rb:159:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.8/lib/action_controller/metal/instrumentation.rb:30:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.8/lib/action_controller/metal/params_wrapper.rb:250:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.8/lib/active_record/railties/controller_runtime.rb:18:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.8/lib/abstract_controller/base.rb:136:in `process'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionview-4.1.8/lib/action_view/rendering.rb:30:in `process'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-mini-profiler-0.9.2/lib/mini_profiler/profiling_methods.rb:108:in `block in profile_method'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.8/lib/action_controller/metal.rb:196:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.8/lib/action_controller/metal/rack_delegation.rb:13:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.8/lib/action_controller/metal.rb:232:in `block in action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.8/lib/action_dispatch/routing/route_set.rb:82:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.8/lib/action_dispatch/routing/route_set.rb:82:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.8/lib/action_dispatch/routing/route_set.rb:50:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.8/lib/action_dispatch/journey/router.rb:73:in `block in call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.8/lib/action_dispatch/journey/router.rb:59:in `each'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.8/lib/action_dispatch/journey/router.rb:59:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.8/lib/action_dispatch/routing/route_set.rb:678:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-protection-1.5.3/lib/rack/protection/frame_options.rb:31:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/omniauth-1.2.2/lib/omniauth/strategy.rb:186:in `call!'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/omniauth-1.2.2/lib/omniauth/strategy.rb:164:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/omniauth-1.2.2/lib/omniauth/builder.rb:59:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.5.2/lib/rack/conditionalget.rb:35:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.5.2/lib/rack/head.rb:11:in `call'
/var/www/discourse/lib/middleware/anonymous_cache.rb:123:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.8/lib/action_dispatch/middleware/params_parser.rb:27:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.8/lib/action_dispatch/middleware/flash.rb:254:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/message_bus-1.0.6/lib/message_bus/rack/middleware.rb:55:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.5.2/lib/rack/session/abstract/id.rb:225:in `context'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.5.2/lib/rack/session/abstract/id.rb:220:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.8/lib/action_dispatch/middleware/cookies.rb:560:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.8/lib/active_record/query_cache.rb:36:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.8/lib/active_record/connection_adapters/abstract/connection_pool.rb:621:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.8/lib/action_dispatch/middleware/callbacks.rb:29:in `block in call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.8/lib/action_dispatch/middleware/callbacks.rb:27:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.8/lib/action_dispatch/middleware/remote_ip.rb:76:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.8/lib/action_dispatch/middleware/debug_exceptions.rb:17:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.8/lib/action_dispatch/middleware/show_exceptions.rb:30:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/logster-0.1.6/lib/logster/middleware/reporter.rb:23:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/railties-4.1.8/lib/rails/rack/logger.rb:38:in `call_app'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/railties-4.1.8/lib/rails/rack/logger.rb:22:in `call'
/var/www/discourse/config/initializers/quiet_logger.rb:10:in `call_with_quiet_assets'
/var/www/discourse/config/initializers/silence_logger.rb:26:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.8/lib/action_dispatch/middleware/request_id.rb:21:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.5.2/lib/rack/methodoverride.rb:21:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.5.2/lib/rack/runtime.rb:17:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.5.2/lib/rack/sendfile.rb:112:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-mini-profiler-0.9.2/lib/mini_profiler/profiler.rb:300:in `call'
/var/www/discourse/lib/middleware/request_tracker.rb:64:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/railties-4.1.8/lib/rails/engine.rb:514:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/railties-4.1.8/lib/rails/application.rb:144:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/railties-4.1.8/lib/rails/railtie.rb:194:in `public_send'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/railties-4.1.8/lib/rails/railtie.rb:194:in `method_missing'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.5.2/lib/rack/builder.rb:138:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.5.2/lib/rack/urlmap.rb:65:in `block in call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.5.2/lib/rack/urlmap.rb:50:in `each'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.5.2/lib/rack/urlmap.rb:50:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/unicorn-4.8.3/lib/unicorn/http_server.rb:576:in `process_client'
/var/www/discourse/lib/scheduler/defer.rb:85:in `process_client'
/var/www/discourse/lib/middleware/unicorn_oobgc.rb:95:in `process_client'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/unicorn-4.8.3/lib/unicorn/http_server.rb:670:in `worker_loop'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/unicorn-4.8.3/lib/unicorn/http_server.rb:525:in `spawn_missing_workers'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/unicorn-4.8.3/lib/unicorn/http_server.rb:140:in `start'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/unicorn-4.8.3/bin/unicorn:126:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.0.0/bin/unicorn:23:in `load'
/var/www/discourse/vendor/bundle/ruby/2.0.0/bin/unicorn:23:in `<main>'
(Gareth Coles) #13
Attempting to reply here with my traceback/env/experience of this bug/etc, but my replies aren’t showing up. Is there another way? Maybe I can post a gist?
EDIT: Alright, that worked.
Yeah, if a topic has no "Poll: " at the start of the name and doesn’t have a list, I find that adding "Poll: " to the name will prevent me from adding a list to the post - instead, the edit is rejected (with the linked errors) and I’m given the chance to resubmit it, should I come back to the post.
Otherwise, no error is shown client-side.
(Régis Hanol) #14
