Port 443 Blocked on Discourse Digital Ocean
Setting up Discourse on Digital Ocean
Using Mailjet and the DNS has an A record for community@ariops.org.uk with the server IP but nothing else please advise.
but I am getting this
This script will configure your Discourse installation
Please be sure you have the following information to proceed:
  - Email Address for your Discourse install
  - Domain/Subdomain to use
  - Mail server information (SMTP)
After being prompted for these details the Discourse installer will
download and install the latest version of Discourse and its requirements
This process will take approximately 10 minutes
When you are ready to proceed, press Enter
To cancel setup, press Ctrl+C and this script will be run again on your next login
Ports 80 and 443 are free for use
'samples/standalone.yml' -> 'containers/app.yml'
Found 4GB of memory and 2 physical CPU cores
setting db_shared_buffers = 1024MB
setting UNICORN_WORKERS = 4
containers/app.yml memory parameters updated.
Hostname for your Discourse? [discourse.example.com]: community.ariops.org.uk
Checking your domain name . . .
WARNING: Port 443 of computer does not appear to be accessible using hostname:  community.ariops.org.uk.
SUCCESS: A connection to port 80 succeeds!
This suggests that your DNS settings are correct,
but something is keeping traffic to port 443 from getting to your server.
Check your networking configuration to see that connections to port 443 are allowed.
The first thing to do is confirm that community.ariops.org.uk resolves to the IP address of this server.
You usually do this at the same place you purchased the domain.
If you are sure that the IP address resolves correctly, it could be a firewall issue.
A web search for "open ports YOUR CLOUD SERVICE" might help.
This tool is designed only for the most standard installations. If you cannot resolve
the issue above, you will need to edit containers/app.yml yourself and then type
./launcher rebuild app
The setup script failed with the provided Discourse details
It will rerun. Please address the above issues
Any Ideas?
Are you using their one-click installer or following the standard install guide?
Your hostname is pointing to Cloudflare.
Your first step would be to press the orange cloud next to the DNS entry so it turns grey.
So that actually worked thanks
I am now through the initial setup and I am configuring my admin account (waiting on the email) but I am not receiving the invite mail I am using mail jet and I have enabled TLS any ideas?
admin email is something@ariops.org.uk where the subdomain is community@ariops.org.uk
I am using port 587 for mailjet confirmed functioning SPF and DKIMS
