Positive ssl + change domain?
(Tumi) #1
Hello guys
I got a possitive SSL . What if i want to change the domain for my fresh instance ? I will lose my cert ? Can i use this cert for new domain?
Or mby will be better to do only forwarding for new domain? But the https adres will work or not ? Should i then buy new ssl cert for direct domain witch i want to use??
(Michael Brown) #2
An SSL certificate is only good for the hostnames against which it is issued.
If you change the hostname of your forum, you’ll need a new certificate for the new one.
We use Let’s Encrypt for our SSL certificates so we don’t have to worry about that.
